Re: Brake swap
[Re: moparbrown14]
#1697404
11/15/14 10:40 PM
11/15/14 10:40 PM
RapidRobert
I believe you would bolt on the 9" spindles & everything outward from there with the 9" setup. The only thing different I could think of is the 70 spindles would have the small upper hole for the early UBJ & not sure if the 74 10" spindles would have the small or the large hole. If the 74 spindle has the small hole it is a bolt in & if it has the large hole Doctor Diff has a sleeve to make up the difference between the smaller tapered ball joint and the larger 74 tapered spindle upper hole. iirc it is a match (both have early small ubj/therefore sleeve not needed
