Opinions on new truck vs 2004 600 3500 model #1697022
11/10/14 03:20 PM
11/10/14 03:20 PM
Salt Lake City
camastomcat Offline OP
Salt Lake City
I'm curious what you guys think that drive or work on the newer trucks as to whether or not it's worth it to spend the money for the newer ones. I haul a 40 ft car trailer most of the time. My current 3500 has the chip, exhaust, leather, and runs pretty good still with only 130k miles.
Re: Opinions on new truck vs 2004 600 3500 model [Re: camastomcat] #1697023
11/10/14 04:49 PM
11/10/14 04:49 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
So you have a 2004 3500 CTD with one of the best 5.9L engines out there and you use it to pull a 40' trailer. It is nicely equipped with some factory and aftermarket options and only has 130k. I see no reason at all to be seduced into buying a newer rig The newer 6.7L is less efficient than the 5.9L and with new emissions restrictions, more expensive to operate. A new truck like yours is $62K in my area!!!
I would put the money you would spend on a newer truck in the bank. With proper care your 2004 will last another 20 years and 260K.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Opinions on new truck vs 2004 600 3500 model [Re: camastomcat] #1697024
11/10/14 05:47 PM
11/10/14 05:47 PM
Guitar Jones Offline
I drive a 92 Keep your truck unless you just have to keep up with the Jones's.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
