70 stock 440 valve covers #1696710
11/09/14 10:22 PM
11/09/14 10:22 PM
rockford illinois
1970A13 Offline OP
1970A13  Offline OP
rockford illinois
Time to tighten the valve cover bolts/nuts,how do you prevent the new(6 year old )paint from chipping?use a metric socket one size bigger?
Re: 70 stock 440 valve covers [Re: 1970A13] #1696711
11/10/14 12:24 AM
11/10/14 12:24 AM
IN
ahy Offline
ahy  Offline
IN
Valve cover bolt torque is pretty low... socket on a screw driver handle is about right. Over torquing the VC bolts will bend the covers and make it leak worse. Paint damage from re-torquing will be mostly from turning the bolt... not the socket. Suggest the correct SAE socket and go easy.
If it seeps a little... that's pretty normal. If it has a major leak, tightening may help, or a new gasket, or stiffer cast valve cover. Its not really a "dry" design as original.
