Trans switch? #1696381
11/09/14 01:05 AM
11/09/14 01:05 AM
North Eastern New York State
montessa Offline OP
montessa  Offline OP
I have been considering changing to a powerglide from a 3 speed. My car is 3700lbs and make a little over 900HP. Have any of you guys made this switch?
How much does it affect the 60ft? Will the car improve or lose ET and MPH ? My best is 9.08 @ 148. The 60ft is 1.25. Comments or experiences please?
Re: Trans switch? [Re: montessa] #1696382
11/09/14 06:24 AM
11/09/14 06:24 AM
WA
JD Dart Offline
JD Dart  Offline
WA
Will my car used to run 8.70's with 727. Now I only get 8.90's with powerglide 2,880 lbs 60' 1.199 to 2.0 now 1.28-1.3
Missing 2nd gear hurts ET 1-2 shift with PG takes a while to recover.
If I wasn't running super street class I'd never switch.
Re: Trans switch? [Re: JD Dart] #1696383
11/09/14 08:14 AM
11/09/14 08:14 AM
Q
Quicktree Offline
Quicktree  Offline
Q
JD you probably need a gear/converter change to get back where you were. I personally love the glide. some will tell you after a certain weight you shouldn't use a glide. if I had the extra bucks I would have a glide in my arrow. I say do it, just be prepared to run a lot of gear and get the correct converter.
Re: Trans switch? [Re: Quicktree] #1696384
11/09/14 08:23 AM
11/09/14 08:23 AM
Chesterfield Twp. Mi.
John Burdine Offline
search this topic on the yellow bullet for more responces.
for me it was an easy choice, to many guys running as good or better with a glide. even in heavier cars. you need to get the converter rite, but same can be said for 3 speeds as well. if you have a 4.10, you may need a 4.30, but not a lot more gear.
Re: Trans switch? [Re: John Burdine] #1696385
11/09/14 11:02 AM
11/09/14 11:02 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I say no. Not enough starting line ratio. Talk to someone who's one it at your weight. I talked to a friend who runs a N/SS Chevelle. Its normally in the 8.70 range. The car weighs 3000 w/driver. It picked up aprox .05 with a glide. That's 700 lbs less than you. Everyone I've talked others with 3300+ cars have slowed down. Strip some weight out to meet your goal. Easier on parts, guaranteed results.
Doug
Re: Trans switch? [Re: Quicktree] #1696386
11/09/14 02:31 PM
11/09/14 02:31 PM
WA
JD Dart Offline
JD Dart  Offline
WA
I've tried 3 different convertors and changed the rear gears from 4.30 to 4.56 pick up the 60' but no ET change. Heads are very tired maybe it would be faster.
I'm not saying I don't like it but if you want faster it will not get you there. If you want consistent then it's the number 1 choice.
Re: Trans switch? [Re: JD Dart] #1696387
11/09/14 06:05 PM
11/09/14 06:05 PM
or just sell me your 572 carb to pan and i'll let you know how it runs with a glide @3300lbs.
