Hp increase..
#1696369
11/08/14 11:18 PM
11/08/14 11:18 PM
Posts: 419 NY
F1Scamp
NY
So at MIR a couple weeks ago I had the duster out. Friday night is was running 11' teens at 122.8-.9mph on new tires. Last pass of the night it developed a surge at the top end that was even noticeable on the a/f meter (going lean). Saturday morning I decided to see where the fuel pressure was at since I hadn't checked it in quite a while. It was at the 6psi I set it at, and I decided to bump it up a little and went to 7psi. The first pass revealed it wasn't the pressure and there was crap in the needle and seat. Took it out after cleaning the carb and it went 125.5mph, followed by a few high 124's. Car was noticeably stronger in the top end and it was laying on the 7200 chip for awhile. A/F friday night was 12.9-13.1, Saturday was 12.4-12.8. On the dyno it made more power leaner. One psi, .6a/f richer and it picked up almost 3mph? Previous best mph, which was in better air it went 123.8. Ideas?
Work In Progress- 71' Duster F.A.S.T.- 10.36@130 Smallblock Record Holder.
