The future of Carbs??
#1696155
11/08/14 06:14 PM
11/08/14 06:14 PM
Posts: 9,876 Weddington, N.C.
Streetwize
Weddington, N.C.
www.silverbackcarbs.comInteresting spin, 4 power valves, overlapping butterflies big hole like a predator. It looks like the primary is a conventional butterly, but the secondary looks like it retracts into the body...just like an old GM station wagon, lol
Re: The future of Carbs??
[Re: hysteric]
#1696158
11/08/14 07:34 PM
11/08/14 07:34 PM
Posts: 1,845 Tampa
DusterDave
Tampa
It's a laudable engineering exercise, but I'll believe the horsepower/torque increase claims when I see independent back-to-back dyno testing against a properly tuned conventional style carb.
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: Streetwize]
#1696160
11/08/14 09:36 PM
11/08/14 09:36 PM
Posts: 8,882 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Look again and watch the indentations on the "butterfly" ... the whole thing is a slide.
[Re: Dunnuck Racing]
#1696162
11/08/14 09:52 PM
11/08/14 09:52 PM
Streetwize
Weddington, N.C.
I thought about the SV-1 and wondered why you couldnt have a smaller round butterfly on the same common shaft as the larger one is that through part throttle only the smaller ( internal ) one would open but as more airflow was needed the larger/outer one would open to reclose/overtake the smaller one as it transitioned to WOT. Kind oflike a progressive only one inside the other.
Another way to do it would be like a camera IRIS or a vertical series of wicket gates ( like they use to throttle a hydroelectric turbine) or some variable vane turbos.
[Re: Streetwize]
#1696165
11/12/14 11:08 AM
11/12/14 11:08 AM
Posts: 13,375 Marion, South Carolina [><]
an8sec70cuda
One of those carbs + a Rev-a-nator and gain 100 hp! Let me grab my credit card. I'll be in the 8s N/A!!!
