70 Cuda Throttle Bracket using an Airgap Intake ? #1695829
11/07/14 08:17 PM
11/07/14 08:17 PM
Texas
E
ef8Cuda340 Offline OP
E
Texas
My recent 408 stroker motor build has an Edelbrock Airgap intake and I am wondering if I will need to replace the factory original throttle cable and bracket due to a change in intake manifold height.
If so, which cable length should I order, and who makes the throttle cable brackets that I should use.
Any pictures of your set up would be appreciated.
I will be running a Holley and a 4 spd.
thanks!
Re: 70 Cuda Throttle Bracket using an Airgap Intake ? [Re: ef8Cuda340] #1695830
11/07/14 08:37 PM
11/07/14 08:37 PM
tennessee,usa
mattsmopars Offline
mattsmopars  Offline
tennessee,usa
http://www.ebay.com/itm/MOPAR-Small-Bloc...e-/221593766768
I used one similar to this on my 340 duster with RPM air gap intake, a holley DP and manual shift valve body. It works good with the original cable. I was thinking I had bought mine from Mancini racing, but I am unsure. Hope it helps you out.
Matt
Re: 70 Cuda Throttle Bracket using an Airgap Intake ? [Re: mattsmopars] #1695831
11/07/14 08:40 PM
11/07/14 08:40 PM
tennessee,usa
mattsmopars Offline
mattsmopars  Offline
tennessee,usa
Re: 70 Cuda Throttle Bracket using an Airgap Intake ? [Re: mattsmopars] #1695832
11/07/14 11:40 PM
11/07/14 11:40 PM
Texas
E
E
Texas
thanks, this one should work just fine!
