Page 1 of 4 1 2 3 4
How Fast before Frame Connectors are needed ? #1695710
11/07/14 04:10 PM
11/07/14 04:10 PM
Or more accurately, how quick ? On a 70 B-body in particular, how quick could one hope to run without doing any permanent damage (twisting) to your unibody ? Do not want a bar, possibly open to the US car tool frame connectors as they look almost factory. Even with those, how quick could one hope to run, 1.50ish 60's ?? Would also boxing in the front and rear torque boxes make much of a difference ? Lower radiator core support stiffening braces ??
Re: How Fast before Frame Connectors are needed ? [Re: ] #1695711
11/07/14 04:31 PM
11/07/14 04:31 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Speed really isn`t the issue it`s tying the frames to make a better working more rigid chassis.
Re: How Fast before Frame Connectors are needed ? [Re: Thumperdart] #1695712
11/07/14 05:09 PM
11/07/14 05:09 PM
As I said, I know it is not the speed, but the quickness or 60' times would be the biggest factor.
I did find this video of what appears to be a 70 Bee with no Rollbar, runs 10.60's with 1.56 60' times......looks to have caltracks....
https://www.youtube.com/watch?v=Pzc3yt9M21E&list=PLryldDmlkIM3zhPot22ErcCdMzCXDMWdz
Re: How Fast before Frame Connectors are needed ? [Re: ] #1695713
11/07/14 05:17 PM
11/07/14 05:17 PM
Cincinnati, Ohio
d7cook Offline
d7cook  Offline
Cincinnati, Ohio
I had a 67 RT that ran mid 11's that had cracking in the paint up each side of the cowl by the fender. It got pretty obvious over time. Frame connectors or a roll bar would have probably stopped it. Also are you racing every weekend or an occasional blast on TNT night?
1967 Coronet, 1989 Daytona tube chassis. Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT. -Banned for life from V8Buick.com-
Re: How Fast before Frame Connectors are needed ? [Re: d7cook] #1695714
11/07/14 05:20 PM
11/07/14 05:20 PM
This is for a 98% Street Car, maybe twice a year at the track.
Re: How Fast before Frame Connectors are needed ? [Re: ] #1695715
11/07/14 05:28 PM
11/07/14 05:28 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
It needs it even if you don't go to the track. They are like a wet noddle without them.
Re: How Fast before Frame Connectors are needed ? [Re: Challenger 1] #1695716
11/07/14 05:43 PM
11/07/14 05:43 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I would think once it got to the point where it needed a bar (12.0 - 11.50s) it needs to have frame ties. Mid 13s and quicker it will certainly help. I wouldn't put a bar in without them. How you tie it up makes a big difference also. Bolt-ins are a waste of time. The 2x2 pre-fab weld-in kits are OK, but if you want it as stiff as possible, 2x3 sectioned into the floor is how it should be done.
Re: How Fast before Frame Connectors are needed ? [Re: ] #1695717
11/07/14 05:50 PM
11/07/14 05:50 PM
an8sec70cuda Online content
an8sec70cuda  Online Content
These old unibodies need frame ties regardless in my opinion. If the motor will be somewhat healthy and you'll drive like it was meant to be driven, then put some connectors on it.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: How Fast before Frame Connectors are needed ? [Re: an8sec70cuda] #1695718
11/07/14 06:41 PM
11/07/14 06:41 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Everything needs the frames tied together regardless of ET. If it twists or flexes even a little bit, that's too much. Don't waste your time on bolt ins
Monte
Re: How Fast before Frame Connectors are needed ? [Re: Monte_Smith] #1695719
11/07/14 08:21 PM
11/07/14 08:21 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
I welded some into my demon- wow what a difference just normal driving. A lot of squeaks were gone, it cornered flatter, launched straighter, just plain felt better. Night and day. I used 1/8" wall 3x2 steel and instead of notching the floor I notched and tapered the rear up to surround the front of the rear frame stubs.
Sorry to pile on the bandwagon even though I don't have any twisting at launch info but just do it!
Re: How Fast before Frame Connectors are needed ? [Re: Monte_Smith] #1695720
11/07/14 08:28 PM
11/07/14 08:28 PM
Monte
I'll second that...
Re: How Fast before Frame Connectors are needed ? #1695721
11/07/14 09:50 PM
11/07/14 09:50 PM
dogdays Offline
dogdays  Offline
The first time I saw the cracking/deformation was in the '70s and it was pretty much any unibody with a 440 in it.
I don't think it's a waste even if you never hit the track. Jack up one corner of your car and watch the door gaps change.
Chrysler made the cars to serve the 99% of people who used them to drive to work or the market or on vacation or etc. They were not building drag racers unless it was one of those special cars, even those they figured the real racers would be modifying the car for their purpose.
Chassis science has improved by a factor of five over the years. Don't be stuck in the '70s.
R.
Re: How Fast before Frame Connectors are needed ? [Re: dogdays] #1695722
11/07/14 10:21 PM
11/07/14 10:21 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
The stamped floor pan is where most of the strength of the unibody is. Sectioning the tubing into the floor and fully weld it, as opposed to a couple of inches of attachment in the front and rear, makes a big difference. I also like to see the cage attached to the inside of the body in strategic locations, rather than just sitting on the floor pan. Make the body shell one interconnected unit, top to bottom, where the pieces all strengthen and support each other.
Re: How Fast before Frame Connectors are needed ? [Re: CMcAllister] #1695723
11/07/14 10:57 PM
11/07/14 10:57 PM
I appreciate all the comments. It seems the consensus is the make it as rigid as possible, but like I said this will be a car that goes to the track maybe twice a year. I personally like things looking as original as possible, yet I would be bored running 13's , 12's....
Any first hand experience with using the US Car Tool Connectors ?
My biggest concern is they are only 12 gauge, and the floorpan is probably less, so....
Do they really stiffen things up ?
What about additionally boxing the front and rear torque boxes, is that worth doing ?
And the front Radiator support stiffener ?
In theory it looks like a good idea, just wondering if anyone has first hand experience with these items.
It is an Original 6 bbl car, so the most I am willing to do is install the US Car Tool style connectors/parts, as they look somewhat factory, to me.
What brought this to mind is this video I saw of a 70 Bee running 10.60 with 1.56 60' times without a bar. This is the type of car that appeals to me.
Re: How Fast before Frame Connectors are needed ? [Re: ] #1695724
11/08/14 12:49 AM
11/08/14 12:49 AM
Minnesota
DLewis Offline
DLewis  Offline
Minnesota
I'm currently putting the complete chassis stiffening pack and frame ties from US tool in my B Body. Not sure where you are in WI but I'm in MN and you're welcome to come check it out. My last car had 500HP and I did weld in frame ties that only fastened at the front and back (not along the floor). I never took it to the track but like stomping the throttle on my way to the Saturday night car shows. When I sold the car it was pointed out that the car had started to twist. I'm not a structural engineer but the material from US Tool is thicker than the floors, frame, and rockers on the car. It's just shy of $800 to put all their stiffening products in the car and really doesn't take too much more time than just doing frame ties. Theirs doesn't require cutting slots in the floor so the carpet will lay down right and the stock appearance isn't changed at all. I can't tell you how well it all works yet, but it seems like reasonable insurance.
Re: How Fast before Frame Connectors are needed ? [Re: DLewis] #1695725
11/08/14 01:03 AM
11/08/14 01:03 AM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
I'd put them on anything I was planning to drive. As others have mentioned, stiffening the chassis can help preserve the car.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: How Fast before Frame Connectors are needed ? [Re: OUTLAWD] #1695726
11/08/14 01:16 AM
11/08/14 01:16 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I put frame connectors and a 6 point rollbar in my 63 street/strip car. I feel the 6 point rollbar stiffened it more then the frame connectors. Its run 10.70's with a best sixty of 1.50. Ron
Re: How Fast before Frame Connectors are needed ? [Re: 383man] #1695727
11/08/14 03:41 AM
11/08/14 03:41 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
you will tweak the body , mess up a nice paint job. Then wish you had done it
Re: How Fast before Frame Connectors are needed ? [Re: 70blackfish] #1695728
11/08/14 04:03 AM
11/08/14 04:03 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I used to have a 64 plymouth 4 speed street / strip car, no frame connectors or bar as it only ran 12.50's. When I got rid of that car there was not only cracks on the A pillar, I could stick my finger between the windshield and the A pillar because the body was twisted so much. On my 67 Barracuda , A pillars have cracked and the floor tunnel is twisted / buckled even with frame connectors and a 6 point bar. Also , most sheet meat on older cars were 20 gauge or less. 12 gauge is fairly thick, 10 gauge is 1/8".
Re: How Fast before Frame Connectors are needed ? [Re: Monte_Smith] #1695729
11/08/14 09:41 AM
11/08/14 09:41 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Monte
If you can find a set of bolt ins cheap weld them in place, it makes a difference.
My '67 was beat on so bad I cracked the trans tunnel over time. I ended up installing a used set from a swap meet missing the hardware so we just welded them in. Night and day difference!
Edit- I was running 13.0's at 112 on street tires.
"I think its got a hemi"
Page 1 of 4 1 2 3 4
