1970 440 six pack shaker bubble emblem placement #1695670
11/07/14 01:00 PM
11/07/14 01:00 PM
texas
magnum440 Offline OP
texas
hello group
have original shaker bubble wanting to put the correct tapered 440Sixpack emblems on it for challenger,,,the holes on it now dont line up,,does anyone have the measurements of the 3 holes or pics of emblems installed...thanks in advance
Re: 1970 440 six pack shaker bubble emblem placement [Re: magnum440] #1695671
11/07/14 02:20 PM
11/07/14 02:20 PM
Frederiction. New Brunswick ,C...
RTshaker Offline
RTshaker  Offline
On the interior of the bubble ,you should have three small dimples where the holes could be drilled, for the correct spacing.
Re: 1970 440 six pack shaker bubble emblem placement [Re: RTshaker] #1695672
11/07/14 03:49 PM
11/07/14 03:49 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Look closely and you will see dimples or outlines.
MLR426
Re: 1970 440 six pack shaker bubble emblem placement [Re: MLR426] #1695673
11/08/14 02:18 AM
11/08/14 02:18 AM
texas
texas
hello thanks for response,,i did find some outlined circles on the interior of bubble...the previous owner had drilled different holes,,i had some steel hood emblems and they fit the holes....the shaker elbems have the pins in drifferent locations...i went ahead and drilled the 2 other holes..but the emblems seem to be at an angle...is this correct?
Re: 1970 440 six pack shaker bubble emblem placement [Re: magnum440] #1695674
11/08/14 02:21 AM
11/08/14 02:21 AM
texas
texas
heres with steel hood emblems which seem more parallel with hood......
Re: 1970 440 six pack shaker bubble emblem placement [Re: magnum440] #1695675
11/08/14 02:40 PM
11/08/14 02:40 PM
MD
floyd Offline
floyd  Offline
MD
Original bubble, original emblem 1
Re: 1970 440 six pack shaker bubble emblem placement [Re: floyd] #1695676
11/08/14 02:41 PM
11/08/14 02:41 PM
MD
floyd Offline
floyd  Offline
MD
#2
Re: 1970 440 six pack shaker bubble emblem placement [Re: floyd] #1695677
11/08/14 02:42 PM
11/08/14 02:42 PM
MD
floyd Offline
floyd  Offline
MD
Original bubble, original emblems. Pins locations are the same for both emblems.
Re: 1970 440 six pack shaker bubble emblem placement [Re: floyd] #1695678
11/08/14 02:42 PM
11/08/14 02:42 PM
MD
floyd Offline
floyd  Offline
MD
other side
Re: 1970 440 six pack shaker bubble emblem placement [Re: floyd] #1695679
11/08/14 09:45 PM
11/08/14 09:45 PM
texas
texas
hello floyd thanks for reply..looks like the 440 is on left side is actually bent upwards,pic #2 looks more even ..i used an 11/64ths drill bit trying to keep holes as small as possible, it was tight going on and i noticed after taking it off it did bend the 440 upwards ,,i stuck a drill bit in the interior outlined circle its almost 1/4 inch,,,is that about the size of the original holes? thanks in advance...
Re: 1970 440 six pack shaker bubble emblem placement [Re: magnum440] #1695680
11/08/14 10:25 PM
11/08/14 10:25 PM
MD
floyd Offline
floyd  Offline
MD
magnum - maybe someone with a bare bubble will chime in. Sorry, but I'm going to pass on pulling the emblems to measure the hole. The original studs are somewhat prone to breaking and the speed nuts sometimes take a little material each time they go on and off. I think your first picture looks pretty similar to my first picture. The D/S emblem seems to angle up a little more. It's probably exaggerated by the large 440 sixpack emblem. Maybe someone will post a pick of the 426 Hemi emblem which is also kind of large. I'm pretty sure all the holes/studs were the same regardless of emblem.
Re: 1970 440 six pack shaker bubble emblem placement [Re: floyd] #1695681
11/11/14 01:11 AM
11/11/14 01:11 AM
texas
texas
hello floyd ..its amazing that you have those parts....and i understand..pics helped alot..thanks to all who responded..
Re: 1970 440 six pack shaker bubble emblem placement [Re: magnum440] #1695682
11/11/14 06:06 PM
11/11/14 06:06 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I always like to back up Floyd.
Here is an NOS emblem on an NOS bubble.
Slants upwards.
Re: 1970 440 six pack shaker bubble emblem placement [Re: Morty426] #1695683
11/11/14 06:08 PM
11/11/14 06:08 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Here are the pins to show spacing. Note that the middle pin is not inline with the outer pins.
Morty
