Best way to clean my heater box? #1695567
11/07/14 05:07 AM
11/07/14 05:07 AM
Erda, UT
67Charger Offline OP
Erda, UT
What are you guys doing to clean up the fiberglass box when the heater is apart for a rebuild/reseal? I just pulled out nearly a cubic foot of debris/sticks/turds from my cowl vent leading into the box and want to get it nice and clean before doing the new foam kit I just received.
Soap and water?
Castrol SuperClean?
Simple Green?
I have a bead blaster and powder coater for the metal stuff.
11.33 @ 118.46 on motor
10.75 @ 125.35 w/ a little spray
Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race
Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
Re: Best way to clean my heater box? [Re: 67Charger] #1695568
11/07/14 07:16 AM
11/07/14 07:16 AM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
I just use soap and water.....then air blow it dry....not like its gonna rust or anything
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Best way to clean my heater box? [Re: 67Charger] #1695569
11/07/14 10:23 AM
11/07/14 10:23 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I pressure washed mine with just water and no chemicals.
Re: Best way to clean my heater box? [Re: 67Charger] #1695570
11/07/14 12:29 PM
11/07/14 12:29 PM
Soap and water?
Castrol SuperClean?
Simple Green?
I'd use some dish soap in a 5 gallon bucket with a scrub brush. No exp with CSC or SG but I hear they are good & depending on their intended app if they remove oily residue they'd be a better choice if you have oily residue that needs to be removed on/in the box but for non oily basic dirt cleaning highly likely dish soap would get that fiberglass looking real nice
Re: Best way to clean my heater box? [Re: RapidRobert] #1695571
11/07/14 12:44 PM
11/07/14 12:44 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I used a de-greaser called "Solvs-it" or Mean green. No harse scrubby and it looks great.
Re: Best way to clean my heater box? [Re: fastmark] #1695572
11/07/14 12:48 PM
11/07/14 12:48 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I just washed mine with soap/water. My Challenger box was nice enough to not need anything else once it was clean. The box in my Dart still looked bad after it was cleaned. I scuffed it and then sprayed it with a clear coat.(semi-gloss) That brought back the shine and made it look new again.
Re: Best way to clean my heater box? [Re: burdar] #1695573
11/07/14 02:09 PM
11/07/14 02:09 PM
None
71rm23 Offline
71rm23  Offline
None
Put mine in the bathtub and used soap and water here. It cleaned up real good
Re: Best way to clean my heater box? [Re: 67Charger] #1695574
11/07/14 02:30 PM
11/07/14 02:30 PM
Erda, UT
Erda, UT
Well, OK then. We'll start trying from the bottom up. Bucket of water, soapy water, pressure washer, fire from space. The Challenger is NASTY in all the little crevices.
Re: Best way to clean my heater box? [Re: 67Charger] #1695575
11/07/14 02:39 PM
11/07/14 02:39 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
If you have a bad one you can lightly soda blast and then coat with matt clear or semi gloss clear. It brings back the original color and finish.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Best way to clean my heater box? [Re: 67Charger] #1695576
11/07/14 04:38 PM
11/07/14 04:38 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
Start with the basics first,,simple soap and water.
From there I'll use simple green and either a stiff bristle brush and a stiff paint brush to get in the little nooks and cranies.
If all else fails "LIGHTLY' glass bead it and clear with Eastwoods satin clear finish.
https://www.facebook.com/pages/AM-High-T...9495&type=3
