Re: Stage6 heads?
[Re: Viper469]
#1694996
11/06/14 01:14 PM
11/06/14 01:14 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
yep.
how do you see the "tree" with all of that?
Re: Stage6 heads?
[Re: buck440]
#1694997
11/06/14 01:38 PM
11/06/14 01:38 PM
Posts: 75,078 U.S.S.A.
JohnRR
U.S.S.A.
Hi guys. can anyone tell me if I can use a tunnel ram with stage 6 heads?
If you put them on an RB block you will need spacers to run an RB manifold. Mopar made/makes a specific 4bbl intake to use on an RB block without spacers , I do not know if they make a tunnel ram version .
Re: Stage6 heads?
[Re: Bill MeLater]
#1695002
11/06/14 11:14 PM
11/06/14 11:14 PM
Posts: 3,831 N.E. Ohio
6bblFLASH
N.E. Ohio
DLI modified Offenhauser for a blower
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Stage6 heads?
[Re: buck440]
#1695005
11/08/14 11:04 AM
11/08/14 11:04 AM
Posts: 16,512 On the run…
BloFish
On the run…
I would like to try a tunnel ram set up on my 500ci/575 hp crate engine. Just need to start looking for parts.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
Re: Stage6 heads?
[Re: buck440]
#1695006
11/08/14 01:08 PM
11/08/14 01:08 PM
JohnRR
U.S.S.A.
Thanks guys mine are on my 440. they have spacers. The reason I ask is my team g manifold will not bolt up center bolt holes are off?
In which direction ?? Is just the manifold off or are the spacers also off ?
