Page 1 of 3 1 2 3
How much gain for heads? #1694579
11/04/14 11:46 PM
11/04/14 11:46 PM
middle Tennessee
mopower440 Offline OP
middle Tennessee
The engine in my dart is a 1975 440:
.030 over
Trw L2355 six pack pistons
compression is 9.4:1
MP 284/484 cam installed 2 or 4 degrees advanced. (cant remember, been a while)
Bone stock 452 heads
Stock intake
Demon sizzler thermoquad
Hooker 1 7/8 fenderwell headers
3000 stall convertor.
Thinking of getting some heads. I would not be able to afford any porting to the new heads so they need to be good flowing right out of the box compared to my stock 452 heads. SO, if i got a set of new edelbrock heads or something similar, what kind of HP and torque gains could i expect? They say the edelbrocks and all these other heads right out of the box outflow the stock heads ported to the max...Is that true?
Re: How much gain for heads? [Re: mopower440] #1694580
11/04/14 11:54 PM
11/04/14 11:54 PM
I'm sure those 2.08/1.74 OE iron heads are holding you back. May I ask what is your SCR & Some OE iron SB intakes such as the 360 spreadbore piece are very good pieces, not sure about BB ones. Are your muffs free flowing/mandrel bends front to rear. Dist subsystems spot on?
Re: How much gain for heads? [Re: mopower440] #1694581
11/04/14 11:56 PM
11/04/14 11:56 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
look into the moparts tech archives and try to draw some conclusions of your own. there are flow numbers and commentary there. your going to hear all kinds of stuff on this subject. i bought my first set of edelbrocks this spring and feel as if they're over rated compared to the iron heads i took off. but, you will see a noticable difference over stock heads. i don't think they're worth $1600 but others may. one man's poison is another's cup of tea.
Re: How much gain for heads? [Re: mopower440] #1694582
11/05/14 12:10 AM
11/05/14 12:10 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
If I was a BB guy in your boat this would be my first choice along with an RPM intake.
Too bad they made another head for a flooded market instead of a SB twisted wedge magnum.
https://board.moparts.org/ubbthreads/show...e=0#Post8320924
Re: How much gain for heads? [Re: HotRodDave] #1694583
11/05/14 12:24 AM
11/05/14 12:24 AM
middle Tennessee
middle Tennessee
Figured heads are the next step, trying to make this thing fast as possible. Got chevy buddies wanting to race, so we may all be going to the track..Heads dont necessarily have to be edelbrocks, just something that will do much better than my stocks.
Re: How much gain for heads? [Re: mopower440] #1694584
11/05/14 01:01 AM
11/05/14 01:01 AM
Stow,Ohio
RBSat66 Offline
RBSat66  Offline
Stow,Ohio
Just be careful what you buy, a friend of mine bought a set of heads and then found out he had to buy the manufactures valve assembly too. I went with Edelbrocks 7 years ago and haven't had any issues. They use stock valve train components. I had 915 iron heads on and when I went to the Edelbrocks out of the box I saw a good bit more performance.
Re: How much gain for heads? [Re: mopower440] #1694585
11/05/14 03:14 AM
11/05/14 03:14 AM
Cab_Burge Online work
Cab_Burge  Online Work
I had several sets of 906 ported and added bigger valves, 2.14 intakes and 1.81 exhaust. They average 266 CFM on the intakes at .600, the OOTB Eddy RPM flowed 284 at .600 valve opening on the same bench Thats 40+ HP plus the weight off of the nose of the car
Re: How much gain for heads? [Re: mopower440] #1694586
11/05/14 12:26 PM
11/05/14 12:26 PM
an8sec70cuda Offline
Call Todd Marsh and ask about the Sidewinder heads he sells. They're truly ready to bolt on when you get them from him.
http://www.mopartsracing.com/
You will see a big performance increase over the stock heads. Lose that stock intake and get a good aftermarket one at the same time.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: How much gain for heads? [Re: Cab_Burge] #1694587
11/05/14 12:33 PM
11/05/14 12:33 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Okay, this strikes a nerve with me.
Why do I care what the heads will flow at .600, .700, or higher lifts? Why does the OP care what the heads will flow above his .484 lift cam? He will never see it so it doesn't matter.
The cam I have coming for the Imperial has a .463 lift. I don't care if the heads fall out and completely stall at .600 lift. If they work well at .400 to .450 then I'm happy. It'll spend so little time between .450 and .463 that the flow there really doesn't matter.
- Stu Harmon
Re: How much gain for heads? [Re: HotRodDave] #1694588
11/05/14 02:12 PM
11/05/14 02:12 PM
Pennsylvania
Red 79 Offline
Red 79  Offline
Pennsylvania
I had the same thought. With the huge increase in popularity for big cube small blocks it seems there is a large void in the cyl head market.
Re: How much gain for heads? [Re: Red 79] #1694589
11/05/14 02:22 PM
11/05/14 02:22 PM
dogdays Offline
dogdays  Offline
There still isn't a decent block to use with a smallblock head that's over 300cfm, so why bother?
R.
To the OP: Your stock heads flow no better than 228cfm stock, and that's the best port. There's a 100hp potential in a set of Stealths, or Sidewinders which seem to the the latest and best budget head, or the ProComps, or the Edelbrocks even the street ones.
Performer RPM intake should be on your list as well.
Re: How much gain for heads? [Re: feets] #1694590
11/05/14 02:36 PM
11/05/14 02:36 PM
The reason I posted the flow results for my motor is that is what lift I had, if he is changing heads now when will he change cams? BB wedge motors love having the valves open further and longer to make more power, same thing on bigger carbs.
Re: How much gain for heads? [Re: mopower440] #1694591
11/05/14 03:41 PM
11/05/14 03:41 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
edelbrock heads are commonly said to be worth 50 HP over stock ones.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: How much gain for heads? [Re: dogdays] #1694592
11/05/14 03:55 PM
11/05/14 03:55 PM
middle Tennessee
middle Tennessee
R.
I. I've been wanting an edelbrock rpm intake but everyone says its so tall that the carb will hit the hood and I'm not sure I want to cut a hole in my hood. Edelbrocks ain't my only prospects, stealths sound good also, just. Want heads that use the stock locaztion of the exhaust ports si I don't have to change my headers and would prefer to use my stock rockers and shafts. I am willing to upgrade my cam..
Re: How much gain for heads? [Re: feets] #1694593
11/05/14 04:00 PM
11/05/14 04:00 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
This is my reasoning also and that is part of why I say the new trick flows, the chamber is waaaaaay better looking than the 40 year old chamber in the eddy, stealth, sidewinder... a good chamber like that tends to help at low lifts a lot. The better chamber gives better mixture that also helps. You are on the right track with the flow but there is still more to it like port volume/velocity mixture quality weight...
Re: How much gain for heads? [Re: HotRodDave] #1694594
11/05/14 04:13 PM
11/05/14 04:13 PM
The Edelbrock, Stealth, Pro Comp, etc., heads all need to be gone through by a machine shop before being bolted on. The Trick Flow heads aren't even available yet.
Todd Marsh has the Sidewinders he sells already checked out and any issues corrected.
CHIP
Re: How much gain for heads? [Re: HotRodDave] #1694595
11/05/14 04:17 PM
11/05/14 04:17 PM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
Call Todd Marsh,, I showed here my 1/4 time increase from my 906 heads to bolt on heads from Marsh and went from 11.7 @ 114 mph to 11,4 at 119 ,,had to fatten the carb up some ,,and it pulled extra 4000+ RPM before the power fell off..used to die off about 5500 rpm now pulls hard thru 6K.
Re: How much gain for heads? [Re: an8sec70cuda] #1694596
11/05/14 04:27 PM
11/05/14 04:27 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Going "waaaaaay back" in history here, but the data is still valid IMO.
Had stock rebuilt 440 w/ unported 906 heads, a 222 @ .050" x .455" hydraulic cam, stock converter, 3.55 gears, 1-3/4" headers, etc. With sticky street tires it ran a best of 13.2 @ 103 MPH.
Picked up a set of '452' castings machined for 2.14" / 1.81" valves. I did a fairly extensive home porting job on them w/ some touch-ups done by a local cylinder head shop. Swapped heads, along with switching from OEM stamped 1.5 rockers to Crane 1.6 iron rockers.
With no other changes, the first time I went back to the track the car ran a 12.5 @ 109 MPH, although the weather was awesome and the car dropped off a bit from that under more average conditions. Still, that means the head porting and increased rocker ratio for the small cam picked up 40-50 HP.
As suggested above, I'd be looking at set of "prepped" Sidewinder heads to get some serious CFM improvements in the <= .500" lift range.
"Your results may vary!"
Re: How much gain for heads? [Re: BradH] #1694597
11/05/14 04:34 PM
11/05/14 04:34 PM
Years ago my car ran 11.87 at 111.9 mph w/ a set of bone stock 906 heads on a 509/292 MP cammed 440. I switched to a set of mildly home ported 915 closed chamber heads...no other changes and the car ran 11.40 at 117.4 mph in similar conditions. That gain in flow and a little compression REALLY woke it up. Was a whole different animal.
CHIP
Re: How much gain for heads? [Re: an8sec70cuda] #1694598
11/05/14 07:36 PM
11/05/14 07:36 PM
middle Tennessee
middle Tennessee
tell me more, what was the rest of the combo?
Page 1 of 3 1 2 3
