1970 Axle and Valve cover markings #1694496
11/04/14 08:39 PM
11/04/14 08:39 PM
Phoenix, AZ
MCTPhoenix Offline OP
Phoenix, AZ
Hi everyone... working on a '70 383 roadrunner with Automatic. I've got what's left of the build sheet trying to figure out what codes belong on the valve covers and 8-3/4 axle housing and center section. On the build sheets under axle, D is the number 56. Also, next to P/shaft is another axle section coded 052. Where and what/which get's stamped on the axle housing and the center section? Also, I can't find anyting anywhere that would indicate what belongs on the front of the valve covers. Thanks everyone!
Re: 1970 Axle and Valve cover markings [Re: MCTPhoenix] #1694497
11/05/14 03:14 AM
11/05/14 03:14 AM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
My Lynch Rd 9/69 built 70 had a white oil paint pen "x" on the round part of the housing center and an orange spray paint dot below the fill plug on the carrier. I know the orange spray mark signifies limited slip fill. The x must be an inspector mark. I may have a documentation pic.
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
Re: 1970 Axle and Valve cover markings [Re: MCTPhoenix] #1694498
11/05/14 03:34 PM
11/05/14 03:34 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Differential color codes
Re: 1970 Axle and Valve cover markings [Re: John_Kunkel] #1694499
11/06/14 01:05 AM
11/06/14 01:05 AM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
THis should help with other markings
1970 Superbird 440-6bbl, auto
1969 Barracuda 340-4bbl, FB Formula S auto
1969 Barracuda 6.1 L Hemi, 5 speed, Convertible
2022 Can Am Spyder RTL
Re: 1970 Axle and Valve cover markings [Re: RealWing] #1694500
11/06/14 01:06 AM
11/06/14 01:06 AM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
Page 2 of the article
Re: 1970 Axle and Valve cover markings [Re: RealWing] #1694501
11/06/14 01:19 AM
11/06/14 01:19 AM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
These are the markings I reproduced on my (Lynch Road) Superbird 8-3/4 axle. As indicated in the previous article, you need to carefully inspect the rear axle to look for these marks before restoration since there doesn't seem to be any consistency.
Re: 1970 Axle and Valve cover markings [Re: RealWing] #1694502
11/06/14 01:20 AM
11/06/14 01:20 AM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
a front shot
