Page 5 of 9 1 2 3 4 5 6 7 8 9
Re: Trick Flow introduces BBM heads [Re: Twostick] #1694203
11/06/14 04:56 PM
11/06/14 04:56 PM
The Great White North
RAMM Offline
RAMM  Offline
That's why I don't understand why all these head mfg's insist on plugging in the same stone age combustion chamber into a Mopar head.
When the SBC Vortec head came out, Hot Rod did a back to back comparison between a conventional SB head and the new Vortec. IIRC they both flowed similar numbers but the V head had a smaller combustion chamber so compression was up about a 1/2 point.
On the same nothing fancy short block the V head was 70 HP better peak and did it with less than 30 deg of timing. IF you can believe HR Mag.
Trick Flow seems to have figured out it doesn't cost any more to make the right combustion chamber pattern than the wrong one. If this chamber shape works as well as the Vortec one apparently does, they will sell boat loads of them.
Kevin
Every Vortec headed engine I test (mainly '602 crates) best timing for max torque and hp is 32 total. As an aside the overhead and dual plug arrangement and possibly being a tumble port is what contributes most to the G3's lack of timing requirements--not chamber shape in and of itself. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: Trick Flow introduces BBM heads [Re: RAMM] #1694204
11/06/14 05:57 PM
11/06/14 05:57 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Yes the Hemi is tumble ports, something a lot harder (but possible usually at the expense of flow) to achieve with a wedge.
I also seem to keep seeing guys building the new hemi are claiming no difference firing both or only one plug, what have you found?
Re: Trick Flow introduces BBM heads [Re: HotRodDave] #1694205
11/06/14 06:19 PM
11/06/14 06:19 PM
RAMM Offline
RAMM  Offline
When you think about it--How can there be the same timing lead required when you have 2 plugs on opposite sides of the chamber? J.Rob
Re: Trick Flow introduces BBM heads [Re: HotRodDave] #1694206
11/06/14 06:28 PM
11/06/14 06:28 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
They might not see a difference in power but I would bet if they had an emissions sniffer on it they would likely see a difference there.
Kevin
Re: Trick Flow introduces BBM heads [Re: 1964superstock] #1694207
11/06/14 06:49 PM
11/06/14 06:49 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
More good close up photos here: http://www.hotrod.com/features/1411-tric...2014-sema-show/
Looks like winner to me, but nearly even with Modern CNC Edelbrock RPM head flow. I sure like that nice 21st century 78 cc combustion chamber. If they are priced right and truly ready to bolt on, they will be very tough to beat.
That finish on the CC is by far, 100-1 better than the finish I got on my Indy 440-1 heads. Those will never be right after they got smoothed out enough to bolt on.
Re: Trick Flow introduces BBM heads [Re: RAMM] #1694208
11/06/14 08:11 PM
11/06/14 08:11 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I know it makes sense but every thing I keep reading they say it don't make no difference on dyno or track even read about the guys developing it said it did not make more power but was done for emmissions I was curious if you had tried any with or without and what you found? Only reason I can think of to not change it is they are in really good locations already and the difference is too small to tell
Re: Trick Flow introduces BBM heads [Re: RAMM] #1694209
11/06/14 08:36 PM
11/06/14 08:36 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
What's a tumble port?
Re: Trick Flow introduces BBM heads [Re: MattW] #1694210
11/06/14 09:11 PM
11/06/14 09:11 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
That's a term my Son Matt calls some of the heads I test on my flow bench. Some including some CNC'd ones sound like garbage disposals when I crank it up.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Trick Flow introduces BBM heads [Re: pittsburghracer] #1694211
11/06/14 10:29 PM
11/06/14 10:29 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
A tumble port adds another dimension to the flow of the intake charge. We've all heard of swirl ports, which impart a curving swirl to the charge to help it mix when it enters the chamber.
Think of a tumble port as making the charge do a somersault when it comes in the room.
Tumble ports are not really new, Ford had them on some of the 4.6 and 5.4 32-valve engines of the late 90s-early 00s.
Re: Trick Flow introduces BBM heads [Re: HotRodDave] #1694212
11/06/14 11:33 PM
11/06/14 11:33 PM
RAMM Offline
RAMM  Offline
Not talking about power. The topic was reduced ignition lead. Think about it--2 plugs on opposite sides of the chamber. Light them both off at the same time. How much time does it take to complete the burn from one side of the combustion space to the other? I bet it is a lot less time, which would equal less lead time required. We need to light the mixture ahead of the piston reaching TDC correct? Well it is not hard for me to imagine that if we light it off as the piston is approaching TDC that the piston will be experiencing resistance earlier than ideal. Now take the G3 and you can WAIT to light the mixture because it will burn completely in a shorter amount of time. Interchange the word WAIT with reduced TOTAL timing. This is how I see it anyways. J.Rob
Re: Trick Flow introduces BBM heads [Re: HotRodDave] #1694213
11/06/14 11:36 PM
11/06/14 11:36 PM
RAMM Offline
RAMM  Offline
I don't think Tony Bischoff would go through the trouble of rigging up dual distributors for his EMC winning G3's in 2010 and 2014 if there was not a very real power advantage. J.Rob
Re: Trick Flow introduces BBM heads [Re: Brian Hafliger] #1694214
11/07/14 12:09 AM
11/07/14 12:09 AM
Nebraska
451Cuda Offline
451Cuda  Offline
Nebraska
Unlike every single mopar head out there, these heads are a TRUE bolt on!
And they actually flow as advertised...and they have upgraded hardware.
This is the first of 3 heads they will offer...
Take note what they flow, the quality castings, machine work and parts, then compare them with Eddy or whoever's heads. You'll quickly see they are priced damn good!
For you to say that, I would assume you have a set, and have personally flowed them ??? Please share the details and some photos...Thanks !
I have to follow chain of command, sorry.
Just like the Edelbrock RPM heads are NOT RACE heads, neither are these...I see a lot of mixup about a race head vs. a performance head.
Yes you can race anything, but this first head is not a RACE head...it's intended for performance, quality, and value.
Can't please everybody that's for sure!!
Any clues as to the potential of their top end version?
Re: Trick Flow introduces BBM heads [Re: HotRodDave] #1694215
11/07/14 12:19 AM
11/07/14 12:19 AM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
Hey Brian,
Can you tell us if either one of the next two versions will need piston changes?
Damon
What's the BIG deal about changing pistons?????????? Heck its done everyday. Some guys want to go fast.
Some guys can spend a ton on a motor upgrade and others can't, pistons cost money, labor is certainly worth money even if you do it yourself, re-balancing costs money then if you want a different head someday you got to do the whole thing again... that is the big deal with piston swaps. Also you are gonna have a hard time getting anyone to stock a piston like that so you spend more on a piston and have more wait time. Gonna cost $6000+ at a shop.
Along the lines of what HotRodDave said I have a great block that I can't afford to change. If one of the next head versions would be substantially better than my fully ported MCH Eddies then I would be a buyer in a year or two.
Damon
Re: Trick Flow introduces BBM heads [Re: RAMM] #1694216
11/07/14 02:15 PM
11/07/14 02:15 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Two quick comments:
1. I'd like a set of these heads, even though they'd be a step backwards performance-wise from what I have now, simply because they look cool!
2. After looking through what else Trick Flow offers in heads for all makes, I question if the "Big Guns" here hoping for a new generation high-end BB Mopar head are going to see that from Trick Flow. One of their trademarked slogans is "Ultimate Bolt-on Performance!", and even their top-of-the-line BB Chevy & BB Ford heads don't appear (IMO at least) like anything more exotic than the equivalent of a nicely prepped B-1.
But I'm all eyes & ears when it comes to new BB Mopar heads!
Re: Trick Flow introduces BBM heads [Re: BBR] #1694217
11/07/14 07:06 PM
11/07/14 07:06 PM
BradH Offline
BradH  Offline
Looks like they have an intake manifold as well.
Yep, and it looks a LOT like the E Victor that's too tall for me to get under my hood, too.
Re: Trick Flow introduces BBM heads [Re: BradH] #1694218
11/07/14 07:08 PM
11/07/14 07:08 PM
PA.
"Little"John
"Little"John
PA.
DISCLAIMER: The opinions above have been posted by a street-car test-n-tuner with a "toy" flowbench and a rusty 10-second '73 Challenger that hasn't run since 2009
LOL
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Trick Flow introduces BBM heads [Re: pittsburghracer] #1694219
11/07/14 07:27 PM
11/07/14 07:27 PM
BradH Offline
BradH  Offline
LOL
Hey, I believe in truth in advertising...
Re: Trick Flow introduces BBM heads [Re: BradH] #1694220
11/11/14 01:07 PM
11/11/14 01:07 PM
BradH Offline
BradH  Offline
FWIW, there is a comment from Trick Flow in the article linked below that gives some idea of what they're considering for their next BB Mopar heads:
http://www.dragzine.com/features/sema-co...uction-package/
Re: Trick Flow introduces BBM heads [Re: BradH] #1694221
11/11/14 07:22 PM
11/11/14 07:22 PM
ohio
all spooled up Offline
ohio
these heads are so nice im going to build a big block
Re: Trick Flow introduces BBM heads [Re: 1964superstock] #1694222
11/11/14 07:52 PM
11/11/14 07:52 PM
Utah
topbrent Offline
topbrent  Offline
Utah
Nice looking intake.
