Need help decoding my new engine and car #1693799
11/03/14 04:03 AM
11/03/14 04:03 AM
Tacoma, Washington USA
Adam71Charger Offline OP
Been missing my last C body ever since I sold it. So I finally found one I could afford in decent condition. It's a 1970 Dodge Polara, 2 door, 318, column shift. No dents, just some rust issues behind wheel wells in trunk (from bad rear window seal letting water in.) Doors line up perfectly straight, and shut like a dream. Pretty happy with it.
Anyways, ONTO THE CODES. Im not concerned if the the block is numbers matching, I'd just like to know what it is and where it came from. What do I got?
Vin number: DL23G0D184213
Casting code on 318 drivers side: 2536030 318*1
drivers side exhaust manifold: 3614395
Front of engine I cant make out the last part, it look like the last 2 numbers had a double stamp, unsure. I think it says HM318R 37172772
Re: Need help decoding my new engine and car [Re: Adam71Charger] #1693800
11/03/14 04:10 AM
11/03/14 04:10 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
HM318R 37172772
H = 1972 model year
M = Mound Rd. engine plant
318 = 318 cu.in.
R = regular fuel
3717 = Friday October 1 1971 engine assembly date
2772 = engine sequence number
partial VIN will be stamped on passenger side oil pan rail
Re: Need help decoding my new engine and car [Re: Adam71Charger] #1693801
11/03/14 04:15 AM
11/03/14 04:15 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
per GG's "white book": casting number 1973-'74 318 a-body LH exhaust manifold
Re: Need help decoding my new engine and car [Re: 6bblgt] #1693802
11/03/14 10:53 AM
11/03/14 10:53 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
While you are under the car to check the engine VIN, you can check the transmission VIN as well. It will be on a flat pad on the passenger side of the bell.
