Re: Tube upper control arms...THAT tight??
[Re: Challenger 1]
#1693570
11/03/14 08:56 PM
11/03/14 08:56 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
Upper's Cab. They are Poly bushings also. Which could explain why they feel so tight. According to the answer I got from the vendor: "That's the way they're supposed to feel. And yes, a dead blow hammer is the best installation tool". Hmmmmm...
[Re: cudadoug]
#1693571
11/04/14 01:08 AM
11/04/14 01:08 AM
Posts: 43,207 Bend,OR USA
Cab_Burge
[Re: Cab_Burge]
#1693572
11/04/14 05:04 AM
11/04/14 05:04 AM
cudadoug
I use Poly Bushings in my A arms and lower control arms on my street Duster, they moved up and down real freely before putting in the front shocks and torsion bars I did not try to collapse the outer brackets on the frame to the A arm bushings though by tightening the bolts through them I did use the special grease they supplied to assemble all the parts that they wanted that grease on
What is this "special" grease you speak of?
[Re: cudadoug]
#1693579
11/06/14 12:46 AM
11/06/14 12:46 AM
cudadoug
So the vendor tells me that must the R side on the L of the car. So I switch them...
NOPE, that's not right.
Should have kept the OE arms, I guess...
