Re: quick release steering wheel coulper for stock column?
[Re: upnover]
#1693553
11/02/14 04:25 PM
11/02/14 04:25 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
http://www.jegs.com/i/JEGS/555/60724/10002/-1I have two of those in use with A body steering columns.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: dvw]
#1693558
11/02/14 05:10 PM
11/02/14 05:10 PM
Posts: 9,973 MI, usa
dvw
MI, usa
[Re: dvw]
#1693560
11/02/14 05:13 PM
11/02/14 05:13 PM
dvw
MI, usa
[Re: onig]
#1693561
11/02/14 05:26 PM
11/02/14 05:26 PM
Posts: 5,875 communist bloc of new jersey
jamesc
What mods need to be done?
i have one of those and had to dress the splines a little bit to get it to slide on a stock shaft.
fwiw i believe the wonderful nhra states any QR adapter must be welded. of course there's only a bazillion cars out there with the steering wheel bolted on. maybe it would be ok if they required an nhra approved steering wheel tether at $200 a copy
[Re: dvw]
#1693562
11/02/14 05:30 PM
11/02/14 05:30 PM
Posts: 8,882 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
I bolted the quick release to back of the steering wheel. The portion that stays on the column. I had welded to the orignal nut down inside the can. Cut a slot for the button (wich I extended) to poke out I used a 72-74 e body steering wheel only so I could mount my trans brake button Also used a t style male/female wire connection out of a old wire harness so the wheel could be moved freely when not driving
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
