Bright Blue Metallic/Blue Fire/B5 Blue questions #1693138
11/01/14 11:04 AM
11/01/14 11:04 AM
Deep DEEP SOUTH
LAD 524 Offline OP
LAD 524  Offline OP
Deep DEEP SOUTH
hey guys I see different B5 blue cars and to my eye they kinda look different in "intensity" and brightness. Of course the light plays a huge part in this.
But Im wondering if the earlier B5 Blue cars were a brighter blue (with less black in the mix) than the later ones?
Ive seen some 68 and 70 Chargers/B Bodies that really light up in a "kinda" B5blue and thats the look Im after.
Is the 68 mix/code different from the others and if so, what is the correct paint code for the brighter Blue ?
Or maybe my eyes are playing tricks on me; I really am after the one that pops in the sun.
Anyone know for sure?
Re: Bright Blue Metallic/Blue Fire/B5 Blue questions [Re: LAD 524] #1693139
11/01/14 12:49 PM
11/01/14 12:49 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
1968 was QQ1 Medium Metallic Blue. Different color than B5 which came in later years. I like QQ1 but is personal preference. Here is mine.
Re: Bright Blue Metallic/Blue Fire/B5 Blue questions [Re: LAD 524] #1693140
11/01/14 02:13 PM
11/01/14 02:13 PM
US
BLACK71 Offline
BLACK71  Offline
US
B5 did differ under the code b5...the paint codes started with a letter designating the year that it started..eb5 in 69 used through 70 then in 71 it changed to gb5 which was a bit darker I believe.. E being 69 f is 70 g is 71 etc..
RMNS 10:9-10
Re: Bright Blue Metallic/Blue Fire/B5 Blue questions [Re: LAD 524] #1693141
11/04/14 08:33 PM
11/04/14 08:33 PM
Phoenix, AZ
MCTPhoenix Offline
MCTPhoenix  Offline
Phoenix, AZ
Just went through this on a '70 RoadRunner. Here's an example of how the older colors don't always translate into the newer formulas. EB5 is available in PPG. If you mix it in their Deltron line it's one color. Mix it in their Shopline and it's another color. I'm not talking the difference in color from the '69-'70 color vs. the '71 and up color... this is the same code, formula but different product lines within PPG. Years ago I painted with Deltron. The Shopline is a "newer" "cheaper" line. The kicker is that the Deltron mix is no where near reminiscent of the B5 I remember. Shopline however, matches perfectly. I've heard through the grapevine that Shopline is actually the old Deltron line renamed and that's why the colors are more accurate.
Re: Bright Blue Metallic/Blue Fire/B5 Blue questions [Re: MCTPhoenix] #1693142
11/04/14 08:44 PM
11/04/14 08:44 PM
Waddell AZ
azblackhemi Offline
azblackhemi  Offline
Waddell AZ
Regardless of color or what brand of paint you use make sure you have the paint supplier mix up a small sample first. Then do a spray out and see if it's the right color. If not it can be tinted or reformulated. It's much better to find out the color is wrong BEFORE you buy a gallon and a half of it!
Re: Bright Blue Metallic/Blue Fire/B5 Blue questions [Re: azblackhemi] #1693143
11/04/14 09:11 PM
11/04/14 09:11 PM
Phoenix, AZ
MCTPhoenix Offline
MCTPhoenix  Offline
Phoenix, AZ
[quote If not it can be tinted or reformulated. It's much better to find out the color is wrong BEFORE you buy a gallon and a half of it!
Try to avoid tinting. Avoid variants and stick with a standard you're happy with (after a spray out). Get a mix that's been cocktailed and you may never get it exactly the same if you need to respray a repair area at a later date
