Tire size on my Duster.......suggestions ? #169308
12/17/08 03:59 PM
12/17/08 03:59 PM
Big Island ,VA
JC Childress Offline OP
Big Island ,VA
I have a 70 Duster with a Dana, and leaf springs moved under the frame rails, and factory wheel wells widened to fit flush with the frame rails. Wondering what the max size slick I can fit under there and still have the car sitting nice and low. It has 10' wide American Racing Trackstars, I forget the backspacing. Thanks for any and all help. Any pics would be awesome. I know I need to stretch the wheelwells a little also.
J.C. Childress (434) 665-9541
Re: Tire size on my Duster.......suggestions ? [Re: JC Childress] #169309
12/17/08 04:08 PM
12/17/08 04:08 PM
Tucson, Arizona
clonestocker Offline
Tucson, Arizona
I have ladder bars but still have the stock frame rails w/ tubs. I have a 13x31 Goodyear on a 12" wheel. Took alot off the front on the opening. matt
[img] [/img]
Re: Tire size on my Duster.......suggestions ? [Re: JC Childress] #169310
12/17/08 05:41 PM
12/17/08 05:41 PM
Cab_Burge Online work
Cab_Burge  Online Work
I stretch the 1/4 panel wheel opening five inches on my 1971 street Duster so I could run most any size street tire I wanted to. I have a set of steel aftermarket wheel tubs that go up flush to the stock rear sub frames with ladder bars and coil overs, this picture is with a set of MT ET Street radials, 315x60x15 on a set of 12 inch wide wheels with 6 3/8 back spacing. The rear end is one inch narrower than a stock A body 8 3/4 rear end also. I wanted the cars apperance to look stock so the street racers wouldn't to get alarmed
Re: Tire size on my Duster.......suggestions ? [Re: Cab_Burge] #169311
12/17/08 06:34 PM
12/17/08 06:34 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
I have the same set up as you and and I run a 28X14.50X15 QTP or a 28x13.50x15 mickey et street on a 12 inch wheel with a 5" backspace and I have had them on a 10" wheel with a 3" backspace
Re: Tire size on my Duster.......suggestions ? [Re: joshking440] #169312
12/18/08 11:11 AM
12/18/08 11:11 AM
Big Island ,VA
Big Island ,VA
It looks great ! Did you stretch the front and the rear ?
Re: Tire size on my Duster.......suggestions ? [Re: JC Childress] #169313
12/18/08 04:33 PM
12/18/08 04:33 PM
Blue Ridge, VA
Plumb Wired Offline
Plumb Wired  Offline
Blue Ridge, VA
J.C. - My old Duster had stock rear frame rails with an aftermarket tub to the rail, quarters were opened up 1 1/2" on center and could fit a 31x10.5W tire.
Mike Gray
RIP Monte Smith
aka: OutlawFish
'98 Bickel Dodge Dakota PST
Re: Tire size on my Duster.......suggestions ? [Re: JC Childress] #169314
12/18/08 08:33 PM
12/18/08 08:33 PM
I had the front stretch three inches and the rear two inches, I had the rear end moved forward one inch also Can you see it
Re: Tire size on my Duster.......suggestions ? [Re: Cab_Burge] #169315
12/18/08 08:51 PM
12/18/08 08:51 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
13 x 31 about fills that wheelwell; my Duster is trimmed at the front & rear. 14 x 32 would be very close.
Jeez, Cab, that's the street car?! Nice piece...
