cc's of 915 BB heads #169299
12/17/08 03:51 PM
12/17/08 03:51 PM
RapidRobert Offline OP
what do they generally run? I couldn't find anything in the archives. Any thoughts on how much I can plunge cut around the valves to increase the cc's to get my CR when I need it to be without hitting water? Thank you for your time.
Re: cc's of 915 BB heads [Re: RapidRobert] #169300
12/17/08 03:56 PM
12/17/08 03:56 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Mine CC at 80 this was with the stock valves 2.08 and 1.60.
Re: cc's of 915 BB heads [Re: ademon] #169301
12/17/08 04:08 PM
12/17/08 04:08 PM
Thanks Bro. I didn't realize they were that big, I've been on small blocks too long. I think this will work out ok.
Re: cc's of 915 BB heads [Re: RapidRobert] #169302
12/17/08 07:25 PM
12/17/08 07:25 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I have 2 sets with std valve size. One with SS. chambers range from 77 to 79. Both had a clean-up cut.
Re: cc's of 915 BB heads [Re: BSB67] #169303
12/17/08 07:41 PM
12/17/08 07:41 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Isn't there a link somewhere to get CC specs on port vol also ?
Re: cc's of 915 BB heads [Re: dOc !] #169304
12/17/08 08:47 PM
12/17/08 08:47 PM
What i was thinking of earlier this AM was a 440 block stroker(4.25) with 392 early hemi rods & an olds 403 piston. But after reading(& thinking) some more I'd probably be faster by a plain ol 451 & some of the $899 stealth heads & have one of the head guys here check them over.
