Page 1 of 3 1 2 3
Ring compressors that work good? #1692957
10/31/14 10:41 PM
10/31/14 10:41 PM
Nebraska
72Swinger Offline OP
Nebraska
Been trying to get my engine together and have been having a helluva time getting the pistons to drop in. Had a Proform adjustable 4-4.09 aluminum tapered ring compressor to start and got #1 in reasonably successfully and went to #2 and ruined an oil ring from the piston getting slightly cocked. These 1.5x1.5x3mm ring packs are a pita im finding out. I have discovered even with an old school band compressor that it is REALLY easy to move the oil rings where the bottom oil ring drops a [Edited by Moparts - Family Friendly Site - Keep it clean] hair and then when you go to compress the compressor it hangs up on the oil ring support rail and then you're fubar'd. Pulling my hair out a little here and have ordered a Total Seal tapered compressor for my 4.065 bore. I pulled #1 back out, thank god, and there was aluminum shavings between ring lands from that pos Proform compressor. I found a set of Mahle single ring sets that have what appear to be identical oil rings to fix #2. This sucks, the TS compressor is about 13 days out yet. Gen III Hemi build fwiw.
Mopar to the bone!!!
Re: Ring compressors that work good? [Re: 72Swinger] #1692958
10/31/14 10:48 PM
10/31/14 10:48 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
a fixed diameter tapered ring compressor is definately the way to go. our pistons are all easy push in by hand with no ring hangups.
Re: Ring compressors that work good? [Re: rebel] #1692959
10/31/14 10:57 PM
10/31/14 10:57 PM
Nebraska
Nebraska
Well hopefully this next one will be the last one I buy for this build lol! I didn't even know it existed until last night.
Re: Ring compressors that work good? [Re: 72Swinger] #1692960
10/31/14 11:25 PM
10/31/14 11:25 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Ring compressors that work good? [Re: 72Swinger] #1692961
10/31/14 11:29 PM
10/31/14 11:29 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Re: Ring compressors that work good? [Re: bigtimeauto] #1692962
10/31/14 11:30 PM
10/31/14 11:30 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
I have the same one's .
Re: Ring compressors that work good? [Re: a493demon] #1692963
10/31/14 11:50 PM
10/31/14 11:50 PM
Nebraska
Nebraska
I think the main problem with the Procomp was it had to much taper. A buddy has a Snap On ring/pliers style I will try as a last resort.
Re: Ring compressors that work good? [Re: 72Swinger] #1692964
11/01/14 04:10 AM
11/01/14 04:10 AM
MN
hemidup Offline
hemidup  Offline
MN
Those Gen 3's can be a real treat when installing pistons. I have all the above mentioned style of ring compressor and still had issues. Bent an oil ring, broke a 2nd ring... heck I even tried using zip ties to compress the rings one time. The biggest problem I see with a fresh factory block is the lack of champher at the bore opening. I now touch up the bore openings a tad and the pistons slip right in with any style of ring compressor tool.
Jerry Williams.
Re: Ring compressors that work good? [Re: hemidup] #1692965
11/01/14 12:19 PM
11/01/14 12:19 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I've never had a problem with the adjustable ones that have 2 bands, you tighten it down around the piston with a square 'Allen' type wrench. Then once the piston is in, release the band by pressing a lever.
Just be sure to square up the compressor to the bore before pushing the piston in. I like to let the skirts hang below the ring compressor to square the piston to the bore, then press the compressor to square it up, and a rubber mallet handle to tap the piston down.
**Photobucket sucks**
Re: Ring compressors that work good? [Re: 70Cuda383] #1692966
11/01/14 12:45 PM
11/01/14 12:45 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Am I the only one without a 60" flat screen monitor viewing this thread ?
Re: Ring compressors that work good? [Re: JohnRR] #1692967
11/01/14 02:01 PM
11/01/14 02:01 PM
Nebraska
Nebraska
Nope! HAHA, Bigtime put a bigtime picture in this thread!
I have assembled a handful of engines in my time with either 1/16 or 5/64" ring packs and they have all been a breeze to get together. These metric packs coupled with the support rails are kickin my butt simply because they can hang up so easily before you even try to slide them into the bore. That and im getting older and damn near need a freakin eye glass to be able to even see their alignment. I'll get some pics lol!
Re: Ring compressors that work good? [Re: 72Swinger] #1692968
11/01/14 02:28 PM
11/01/14 02:28 PM
Nebraska
Nebraska
Happy oil rings
Re: Ring compressors that work good? [Re: 72Swinger] #1692969
11/01/14 02:32 PM
11/01/14 02:32 PM
Nebraska
Nebraska
And if you don't have 4 hands and a surgeons precision and bump the opposite side of the lower ring gap when putting the rings compressor on or get it even a fraction cocked in a tapered style this will happen
Re: Ring compressors that work good? [Re: 72Swinger] #1692970
11/01/14 02:50 PM
11/01/14 02:50 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
I used to use the bottom one in the pic below but was then introduced to the one above it and will never use anything else.
Re: Ring compressors that work good? [Re: John_Kunkel] #1692971
11/01/14 02:59 PM
11/01/14 02:59 PM
Nebraska
Nebraska
I have that one on top and I cant get it to sqeeze enough. Tried a few different clockings with it and no matter what I do where that compressor overlaps, I have rings not compressed enough.
Re: Ring compressors that work good? [Re: 72Swinger] #1692972
11/01/14 03:24 PM
11/01/14 03:24 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Been trying to get my engine together and have been having a helluva time getting the pistons to drop in. Had a Proform adjustable 4-4.09 aluminum tapered ring compressor to start and got #1 in reasonably successfully and went to #2 and ruined an oil ring from the piston getting slightly cocked. These 1.5x1.5x3mm ring packs are a pita im finding out. I have discovered even with an old school band compressor that it is REALLY easy to move the oil rings where the bottom oil ring drops a [Edited by Moparts - Family Friendly Site - Keep it clean] hair and then when you go to compress the compressor it hangs up on the oil ring support rail and then you're fubar'd. Pulling my hair out a little here and have ordered a Total Seal tapered compressor for my 4.065 bore. I pulled #1 back out, thank god, and there was aluminum shavings between ring lands from that pos Proform compressor. I found a set of Mahle single ring sets that have what appear to be identical oil rings to fix #2. This sucks, the TS compressor is about 13 days out yet. Gen III Hemi build fwiw. [/quote
Sounds familiar,,with the Total Seal oil rings. I had a set from them that the oil ring expanders were too long. I was like you, pulling my hair out, thinking I was stupid, etc. I finally figured out what was going on,,of course they DENIDE any problem. They were metric rings. I ordered Mahle rings and all was fine.
If you like drag racing, support your local track.
Re: Ring compressors that work good? [Re: John_Kunkel] #1692973
11/01/14 03:26 PM
11/01/14 03:26 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Re: Ring compressors that work good? [Re: 72Swinger] #1692974
11/01/14 03:34 PM
11/01/14 03:34 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Reading back through this thread....I saw this when my Diamond pistons didn't have enough depth in the ring grooves. Ain't the Gen 3 stuff fun!! I was having 2nd thoughts about my ability to build engines for awhile!!! My first Gen 3 Hemi and all these problems... wrong piston specs first, finally get that corrected, then wrong rings,,
Re: Ring compressors that work good? [Re: CHAPPER] #1692975
11/01/14 05:01 PM
11/01/14 05:01 PM
Nebraska
Nebraska
Chapper I am beginning to lean this way myself. I went out in the garage and said wth, lets go for round 2. I held the rod in my vise, got the rings all happy and squared up the Lisle oil filter wrench style compressor and clamped her down. #1 went in past the oil rings on the first punch of my fist. But the compressor then twisted and the top oil ring was barely above the bore and I undid the compressor and got the oil ring completely in then re-clamped and sent it home. Did the same on #2 and it went well except right at the last tap to get it home, it made a SNAP sound, and at the same time a little flake of moly coating flew out of the compressor and landed on my hand. NICE! So right now a set of Mahle rings are sounding pretty fricken awesome.
Re: Ring compressors that work good? [Re: 72Swinger] #1692976
11/01/14 05:11 PM
11/01/14 05:11 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
I may also tell you,,be careful to not try to get the Lisle compressor TOO tight. Overtight causes as much or more trouble as too loose, if you can understand my meaning. Once I got the right oil ring and the right depth on the ring grooves, mine went in easy. FYI,,the next Gen 3 I did, I used Ross pistons with 1/16 1/16 3/16 ring pack and that went WAY smoother.
Page 1 of 3 1 2 3
