no heat after coolant change??? #1692936
10/31/14 07:13 PM
10/31/14 07:13 PM
albany ny
0
05dakota Offline OP
05dakota  Offline OP
albany ny
4.7 dakota, what did i do wrong
Re: no heat after coolant change??? [Re: 05dakota] #1692937
10/31/14 07:31 PM
10/31/14 07:31 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Sounds like you haven't got enough coolant in it yet. Did you make sure the thermostat opened and recheck the coolant level?
Re: no heat after coolant change??? [Re: 05dakota] #1692938
10/31/14 07:44 PM
10/31/14 07:44 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Probably an air pocket. T-stat is on the bottom hose so you'll have to work at it. They make vacuum fillers to pull a vacuum on the system to help remove the air. There may be a bleeder valve some where also.I've pulled the upper hose off the rad and fill the block/heads through that then reinstall and fill the rad, run it, open the bleeder to help remove the air. Good luck....it can be a pain!
Re: no heat after coolant change??? [Re: 05dakota] #1692939
10/31/14 07:48 PM
10/31/14 07:48 PM
albany ny
0
05dakota Offline OP
05dakota  Offline OP
albany ny
got it. after more burping its fine
