Re: 426 Hemi into a 65 B body shock modification
[Re: 6T4 Polara]
#1692881
10/31/14 08:06 PM
10/31/14 08:06 PM
Posts: 5,102 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
I know you have to do it on an 68 A body. Is it also required on a 65 B body? I have a 65 Bel II with the inner fender and firewall work done. That just may be a deal breaker for me if so.
...FAFO...
[Re: skicker]
#1692882
10/31/14 08:51 PM
10/31/14 08:51 PM
Posts: 8,241 fredericksburg,va
cudaman1969
fredericksburg,va
The bump under the shock hole has to be moved away from engine, slice the hole area then flip. You also have to clip the front upper a-arm area, leave a hole there.I'll try to find a pic Here
[Re: hemicar1971]
#1692884
10/31/14 10:38 PM
10/31/14 10:38 PM
Posts: 528 SW CO
HemiSportFury
SW CO
I did not invert the shock tower when I put the 528 in my 64 Sport Fury. The valve cover is very close to the shock stud but I have a tie down on the engine to keep it from rocking so it is not a big deal.
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60 '57 Belvedere 2dr sedan, current project in process '19 Cherokee Trail Hawk Elite '03 Ram 2500 CTD HO, 6-speed 214,000 miles and still going strong
[Re: 6T4 Polara]
#1692889
11/01/14 02:59 PM
11/01/14 02:59 PM
Posts: 25,757 Rio Linda, CA
John_Kunkel
Rio Linda, CA
You gotta remember that engineers are an anal lot, they set clearance standards and won't deviate from them. I've seen a lot of GEN 2 Hemis in early B's with no engine compartment mods.
[Re: cudaman1969]
#1692890
11/01/14 06:21 PM
11/01/14 06:21 PM
cudaman1969
fredericksburg,va
The bump under the shock hole has to be moved away from engine, slice the hole area then flip. You also have to clip the front upper a-arm area, leave a hole there.I'll try to find a pic Here are the pids
[Re: dvw]
#1692892
11/01/14 09:22 PM
11/01/14 09:22 PM
Posts: 9,828 MI, usa
dvw
MI, usa
