Single 4bbl Tunnel Ram for 440? #169284
12/17/08 02:11 PM
12/17/08 02:11 PM
sumlrp Offline OP
sumlrp  Offline OP
Has anyone tried a single 4bbl tunnel ram for the strip? Would like to put a tunnel ram on my mild race 440 but would rather not deal with dual quads. If anyone has made it work please let me know some details?
Thanks.
Re: Single 4bbl Tunnel Ram for 440? [Re: sumlrp] #169285
12/17/08 04:10 PM
12/17/08 04:10 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Haven't tried a single 4 bbl but they make the tops for a single so there must be something to them. Probably give you the same effect as a single 4 bbl on a crossram - like an STR14 - just a different visual impact.
Re: Single 4bbl Tunnel Ram for 440? [Re: Stanton] #169286
12/17/08 04:13 PM
12/17/08 04:13 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Single 4bbl tunnel rams are notorious for fuel distribution problems, two small 4bbl's will be easier to tune & make more power....
Re: Single 4bbl Tunnel Ram for 440? [Re: 1_WILD_RT] #169287
12/17/08 07:18 PM
12/17/08 07:18 PM
sumlrp Offline OP
sumlrp  Offline OP
I was afraid of the fuel distribution issue. Going on a gasser style 33 coupe so wanted the tunnel ram look. I may try 2 600 edelbrocks and see how they work...Here is the project, ignore the BBChevy it is gone.
Re: Single 4bbl Tunnel Ram for 440? [Re: sumlrp] #169288
12/17/08 07:27 PM
12/17/08 07:27 PM
Northwest Chicago Suburb
DaDart Offline
DaDart  Offline
We ran a tunnel ram with two edel's on a pretty much stock 383 with a MP cam and it ran better than the single plane 4 bbl. Now running a Indy ram with two 830's on a 499.
3 Darts and a Ram
Re: Single 4bbl Tunnel Ram for 440? [Re: DaDart] #169289
12/18/08 02:27 PM
12/18/08 02:27 PM
Queens, New York
Harley Offline
Harley  Offline
Queens, New York
I run 2 Holley 750dp carbs on the street with no problem. They run better the the single 850 i had on it. The only problem with them is paying at the pump.
Re: Single 4bbl Tunnel Ram for 440? [Re: sumlrp] #169290
12/18/08 02:47 PM
12/18/08 02:47 PM
Tulsa, OK
73cudaproject Offline
Tulsa, OK
I am not sure how well they would perform; however the long tube cross rams would look awesome on your car.
Re: Single 4bbl Tunnel Ram for 440? [Re: sumlrp] #169291
12/18/08 08:06 PM
12/18/08 08:06 PM
Boston
440800 Offline
440800  Offline
Boston
I would run two small four barrels over a single four barrel on a tunnel ram as well. They aren't hard to setup.
