Vapor seperator #1692644
10/30/14 09:16 PM
10/30/14 09:16 PM
pawling n.y.
cudachas Offline OP
cudachas  Offline OP
pawling n.y.
Where does the vapor seperator bolt to on a 70 hemi. By using one does it eliminate the need for a fuel filter? Whats the easiest way to obtain the .060 restriction .Thanks, Charlie.
Re: Vapor seperator [Re: cudachas] #1692645
10/30/14 11:26 PM
10/30/14 11:26 PM
Arlington, Texas
bobby66 Online content
bobby66  Online Content
Arlington, Texas
I think they bolt to one of the fuel pump mounting bolts. The fuel filters go after the separator, before the carbs. The restriction should be in the return line to the tank.
Re: Vapor seperator [Re: cudachas] #1692646
10/31/14 03:49 AM
10/31/14 03:49 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
On the restrictor, I cut off a bolt, and drilled a hole in it, and put it inside of the rubber gas line. I think that with a separator, there is not a filter. I know the 71s didn't have one.
Re: Vapor seperator [Re: cudachas] #1692647
10/31/14 05:50 AM
10/31/14 05:50 AM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
I ended up with whats in the 1st pic for a 70RR. If its incorrect someone feel free to comment.
Re: Vapor seperator [Re: thehemikid] #1692648
10/31/14 09:03 PM
10/31/14 09:03 PM
pawling n.y.
cudachas Offline OP
cudachas  Offline OP
pawling n.y.
Thanks everyone for your help, looks like mine will mount like the 1st photo you posted hemikid. I think I will use the idea about inserting a 1/4" bolt with a .060 hole in the return line as a restrictor and I will use the seperator as my filter, Thanks again to all!
