HP manifolds with eddy heads #1692632
10/30/14 08:46 PM
10/30/14 08:46 PM
Way North Idaho
1KoolBee Offline OP
1KoolBee  Offline OP
Way North Idaho
I noticed in Andy F's manifold 471 article that he was toasting the #6 & #8 wires when running eddy heads and hp manifolds due to angled plugs. Has anyone run into this and solved the problem? I'd Hate to have to spend $400 extra for mp 452 heads as a solution.
'68 Bee 383/TF/Factory Air...high school sweetheart
'67 GTX Clone project,500 six pack,Hemi4-speed,Dana
05 Dodge Viper, 505 V-10, 6-speed Tremec
Re: HP manifolds with eddy heads [Re: 1KoolBee] #1692633
10/30/14 09:23 PM
10/30/14 09:23 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Accel ceramic booted plug wires
No more burnt boots
Keith
Re: HP manifolds with eddy heads [Re: Dunnuck Racing] #1692634
10/31/14 01:41 AM
10/31/14 01:41 AM
Way North Idaho
1KoolBee Offline OP
1KoolBee  Offline OP
Way North Idaho
No more burnt boots
Keith
Thanks Keith. Do the boots actually touch the manifold or just come close?
Re: HP manifolds with eddy heads [Re: 1KoolBee] #1692635
11/04/14 03:27 AM
11/04/14 03:27 AM
Way North Idaho
1KoolBee Offline OP
1KoolBee  Offline OP
Way North Idaho
No more burnt boots
Keith
Anybody know if plug wire boots touch exhaust manifolds on #6 & #8 when using Eddy heads?
Re: HP manifolds with eddy heads [Re: 1KoolBee] #1692636
11/04/14 11:03 AM
11/04/14 11:03 AM
Weatherford, Texas
RapidusMaximus Offline
Weatherford, Texas
Well I can tell you from a VERY personal perspective from last weekend...sit down and relax, this will take a moment...so last weekend I decided to break the engine in on my 68 GTX, 440, Eddy heads. I have coated TTI headers on the way, VERY specifically they say DO NOT break in a new engine on these headers or it will ruin the coating. OK. no problem I have a set of old hookers hanging in the rafters, I'll just throw those on for the break-in period...ahhh, not so much there buddy, old hookers wont fit eddy's, crap, can't even get the spark plugs in. Ok, looks like we're going to use the manifolds, built stub exhaust pipes, hang some glass packs on it to keep the noise down to where I can here the engine during break-in, sweet, good to go. Yes the plug boots on MSD 8.8 wires are tight, the number 8 does not touch but it has maybe .100 to .200 clearance, the number six however has about half of that...it is real close to touching. During my cam break-in...about half way through it, the number 6 plug wire boot caught on fire , had to put it out with a water gun from my bar-b-que pit operation, number 8 was beginning to smoke when I finished. Yes, they are REAL close to the manifold...your results may vary...
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
Re: HP manifolds with eddy heads [Re: RapidusMaximus] #1692637
11/04/14 11:07 AM
11/04/14 11:07 AM
maryland
74yellowduster Offline
maryland
i only 2 wires during my breakin, you only lost one so you did better lol
