Choosing an ignition coil #1692452
10/30/14 07:50 AM
10/30/14 07:50 AM
Europe
rory73 Offline OP
rory73  Offline OP
Europe
Hi all
I'm about to install a FireCore distributor (not the RTR version) and Rick Ehrenberg's HiRev ECU on my low comp 440. Until now I had a Blaster II coil but that doesn't seem to be recommended with this setup. My old ECU was a standard black 5 pin with 4 pin ballast resistor, by the looks of it the original unit. It worked but the distributor was on the way out and I wanted something better anyways.
Also upgraded to Holley Commander EFI without spark control though as I didn't feel like messing with GM HEI conversion stuff.
Both FireCore and Rick suggest using an OEM style oil filled coil but which one? I don't race my cars but I do want a reliable setup.
Thanks for your input!
Tim
Re: Choosing an ignition coil [Re: rory73] #1692453
10/30/14 10:26 AM
10/30/14 10:26 AM
Ontario,Canada
firefighter3931 Offline
Ontario,Canada
Firecore sells an HP cannister style coil that works great with an MSD .8 ohm ballist resistor. Contact Firecore and order their coil.
The Ballist resistor is available at Summit Racing
Ron
Re: Choosing an ignition coil [Re: rory73] #1692454
10/30/14 11:52 AM
10/30/14 11:52 AM
Tim welcome here . I would ask both of them guys which one they have in mind and also what (ohm) ballast. cuz there are tons of oil filled coils and the coil is what produces the power so you want the best one for your app
Re: Choosing an ignition coil [Re: RapidRobert] #1692455
10/30/14 04:53 PM
10/30/14 04:53 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i'm confused ?? what is wrong with running the blaster with this steup? on a very mild, street only 440 setup? maybe they are saying a blaster 2 is over-kill? I don't see the issue. use what you got bro! if you're running it with the ballast then the current to the coil is reduced and over-heating it is moot.
Re: Choosing an ignition coil [Re: mikemee1331] #1692456
10/30/14 08:32 PM
10/30/14 08:32 PM
IN
ahy Offline
ahy  Offline
IN
I like a "matched setup" on coil and ignition for life and reliability... and depend on makers of the parts for recommendation. I've seen a big high output coil on a stockish ignition fail pretty fast.
Personally I'd go to NAPA and get a stock replacement coil in their premium line (if there are several) since stock was recommended.
Re: Choosing an ignition coil [Re: rory73] #1692457
10/30/14 09:37 PM
10/30/14 09:37 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
When I bought one of the HiRev boxes to test it, it came with specific instructions on which coil and ballast resistor to use.
I don't recall the specifications off hand but I should still have the instructions if you don't have them.
If I remember correctly he wanted a higher resistance ballast and coil than the MSD unit to protect the ecu.
Keith
Re: Choosing an ignition coil [Re: rory73] #1692458
10/31/14 12:05 AM
10/31/14 12:05 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Hi all
Tim
Mopar Performance recommends a 0.25 Ohm ballast with the Blaster II and Chrome box. Keep in mind its resistance increases as the resistor heats up as it primary purpose is to limit the current to the coil.. U can use almost any value around 1.0 ohm..
I have been running the 0.25 Ohm resistor on my warmed over 383 for over 10 years without any issues..
Just my $0.02...
Re: Choosing an ignition coil [Re: Sinitro] #1692459
10/31/14 06:44 AM
10/31/14 06:44 AM
Europe
rory73 Offline OP
rory73  Offline OP
Europe
Thanks for the warm welcome and suggestions everyone!
The ECU hasn't arrived yet, didn't know it comes with more detailed instructions. I'll wait and report back!
Ordered the FireCore via Jegs, here's what they have to say:
Typical Wiring for Muscle Car or Street Rod Installation:
- Mopar Style ECU: 555-40800, 555-40805, 312-P4120505, 312-P412035
- 1 Ohm Ballast Resistor: 555-40103, 312-P5206436
-Mopar OEM or OEM Style (oil filled Coil) or HP Coil 555-40105
Trouble Shooting:
- Use the appropriate BR, 1 Ohm is recommended (minimum of 0.5 Ohm)
- Operation without BR will damage the ECU and Coil
- Do not use a CD (i.e. MSD) coil since this will damage the ECU
- Check voltage between Coil (+) and good ground ... should read between 7.0 and 9,0 Volts
Of course I'd be happy keeping the Blaster II coil, maybe putting a spare in the glove box ;-)
Nothing beats a well matched setup though, even on a street car!
Tim
Re: Choosing an ignition coil [Re: rory73] #1692460
10/31/14 08:51 PM
10/31/14 08:51 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
HP Coil 555-40105
that's Jegs high performance coil. same as the Blaster 2 (45,000v). use what ya got....
Re: Choosing an ignition coil [Re: mikemee1331] #1692461
10/31/14 09:24 PM
10/31/14 09:24 PM
Europe
rory73 Offline OP
rory73  Offline OP
Europe
I don't think it's the same. One uses a 1.6 Ohm ballast resistor, the other 0.8 Ohm.
Re: Choosing an ignition coil [Re: rory73] #1692462
10/31/14 11:00 PM
10/31/14 11:00 PM
Northern Indiana
Northern Indiana
Here ya go,.......
Keith
Re: Choosing an ignition coil [Re: rory73] #1692463
10/31/14 11:19 PM
10/31/14 11:19 PM
AndyF Offline
AndyF  Offline
The MSD box type coil seems to work pretty well with some different ignition systems. They are also easy to mount.
Re: Choosing an ignition coil [Re: Dunnuck Racing] #1692464
11/01/14 06:29 AM
11/01/14 06:29 AM
Europe
rory73 Offline OP
rory73  Offline OP
Europe
Thanks Keith!
Interesting, some of it's verbatim from the instructions that came with the FireCore distributor.
The important bit however would be this line:
"Coil primary resistance should be no lower than 1.4 Ohm"
That's the spec for an old points distributor, which also suggests the 0.7 Ohm Blaster 2 isn't that well suited.
Alot of coil manufacturers don't publish a data sheet, at least not online but what about the Pertronix FlameThrower?
http://www.summitracing.com/parts/pnx-40011/overview/
I've used Pertronix in the past and they're certainly a reputable enough company to buy from. How do I calculate the correct Ballast Resistor though?
Tim
Re: Choosing an ignition coil [Re: rory73] #1692465
11/01/14 07:07 AM
11/01/14 07:07 AM
Europe
rory73 Offline OP
rory73  Offline OP
Europe
Come to think of it: this sounds suspiciously similar to the old FBO setup (A688) where you could swap in a Pertronix coil or Orange Box.
Did Don specify anything about the ballast resistor required? His website being the usual mess I can only find salesman talk about his newer product.
Re: Choosing an ignition coil [Re: rory73] #1692466
11/01/14 07:42 AM
11/01/14 07:42 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
On my daily Dart I've installed a Dyna Mod hei-module along with the above shown square box-type MSD e-core coil.
There's something to say about being able to simply connect ignition parts to a full 12v source and not worry about it anymore after that.
Re: Choosing an ignition coil [Re: BigBlockMopar] #1692467
11/01/14 01:57 PM
11/01/14 01:57 PM
Europe
rory73 Offline OP
rory73  Offline OP
Europe
Sort of made up my mind now. If there are no objections I'll go for the MP 4529795 Ballast Resistor:
http://www.summitracing.com/parts/dcc-4529795/overview/
Strictly speaking a four prong isn't needed and certainly not used by the ECU but it'll snap right in and look correct. Matter of fact I still have a spare Standard Motor Products RU12 lying around but no idea what resistance that has. I *think* it's 1.5 ohm, which would be close to the MP one.
For a coil the Pertronix FlameThrower sounds right, I'll keep the Blaster 2 as spare though.
Maybe I'll change everything for a computer controlled ignition in the future. No doubt light years ahead of the Mopar stuff but for the time being I'll just tweak the existing setup.
Thanks everyone!
Tim
Re: Choosing an ignition coil [Re: Dunnuck Racing] #1692468
11/02/14 11:04 AM
11/02/14 11:04 AM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
Here ya go,.......
Keith
Yikes!! that ECU seems way too touchy for any type of street use but that's just me
