Clutch fan and Fan for a 1970 Hemi Coronet RT #169241
12/17/08 12:43 PM
12/17/08 12:43 PM
wyoming
W
whatif Offline OP
whatif  Offline OP
W
wyoming
Can anyone tell me which size cluch fan and fan is used on a 1970 hemi rt, is it a 215 or 216 and if you know of any for sale or part # so I can try and locate one.Thanks Don
Re: Clutch fan and Fan for a 1970 Hemi Coronet RT [Re: whatif] #169242
12/17/08 02:25 PM
12/17/08 02:25 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I am pretty sure the one you need is a 216. Check on your broadcast sheet. The clutch is the hard part. It should be a 070. They are high $$$. The A12 guys are always complaning about the price and availablity.I may have a pic of mine. I will look on the 'puter.
Re: Clutch fan and Fan for a 1970 Hemi Coronet RT [Re: fastmark] #169243
12/17/08 03:25 PM
12/17/08 03:25 PM
Elizabethtown, KY
6T9Hemi Offline
6T9Hemi  Offline
Elizabethtown, KY
69s use the 215.
1969 340 4 Speed Swinger R4,
black vinyl, white butt stripe, 3:91
Re: Clutch fan and Fan for a 1970 Hemi Coronet RT [Re: 6T9Hemi] #169244
12/17/08 03:51 PM
12/17/08 03:51 PM
wyoming
W
whatif Offline OP
whatif  Offline OP
W
wyoming
thanks for the PIC all I need to do now is hunt if you have any idea please let me know. don
Re: Clutch fan and Fan for a 1970 Hemi Coronet RT [Re: whatif] #169245
12/18/08 12:40 AM
12/18/08 12:40 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I have found several at the wrecking yard. They could be on just about any car. Some are ink stamped and some are some are metal stamped on each blade. Forget which is correct for which date. Ebay is a place you can check.
Re: Clutch fan and Fan for a 1970 Hemi Coronet RT [Re: 6T9Hemi] #169246
12/18/08 10:16 AM
12/18/08 10:16 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
69s use the 215.
All the 383/426/440 b-body 69 cars with N51 Max cooling package used the 18 1/2" 216 fan and the 2806070 clutch.
Re: Clutch fan and Fan for a 1970 Hemi Coronet RT [Re: 62maxwgn] #169247
12/18/08 04:45 PM
12/18/08 04:45 PM
Az
69hemibeep Offline
69hemibeep  Offline
Az
69s use the 215.
My broadcast sheet shows a 215 on my 69. I have a book that shows 1970 hemi with a 2658984 fan and 2806070 clutch it also shows the 216 fan on a/c cars
