trans crossmember q?
#1692320
10/29/14 11:05 PM
10/29/14 11:05 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Putting a 71 cuda together, bb/727 and this crossmember seems to be putting the mount to far foward
I need help with this
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
Re: trans crossmember q?
[Re: sixpackgut]
#1692321
10/30/14 12:11 AM
10/30/14 12:11 AM
RapidRobert
That appears to be a custom fabbed piece
[Re: RapidRobert]
#1692322
10/30/14 10:38 AM
10/30/14 10:38 AM
Posts: 3,136 tennessee,usa
mattsmopars
tennessee,usa
http://brewersperformance.com/proddetail.asp?prod=TC074Chrysler standardized the trans mount location in 70 doing away with the need for two cross members. Then in 71 on b body cars they changed to the spool mount for the transmission. Hard to tell for sure from the picture but yours favors the correct one. I posted a link to brewers website for help. Matt
[Re: moparmarks]
#1692324
10/30/14 12:27 PM
10/30/14 12:27 PM
Posts: 4,285 Ohio
64dodge572
Ohio
Looks like the correct factory 71 piece to me.
I agree. Are you trying to install the mount in the wrong direction?
Brewers Performance Inc. 4-speed transmission and parts specialists PH 937-947-4416 or 937-698-4259 FAX 937-947-4419 www.brewersperformance.com
[Re: 64dodge572]
#1692325
10/30/14 12:32 PM
10/30/14 12:32 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
Tabs, rubber mount goes toward the rear.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: moparmarks]
#1692326
10/30/14 01:32 PM
10/30/14 01:32 PM
sixpackgut
Charleston
I think the poly mount I bought is making the fit a bunch tighter and has a little more meat on the forward edge that mounts to the trans
[Re: moparmarks]
#1692327
10/30/14 10:17 PM
10/30/14 10:17 PM
moparmarks
Excuse me while I work through another brain fart. The mount faces forward.
