I need more positive caster, and they don't make offset bushings for these. I found these specs for the standard bushings. No drawing showing what length C, D, or E are, but they are the same in both. You think .040" is too much to machine from the control arms to get offset bushings to fit? Perhaps I could weld some reinforcement around the hole. What do you think?
Moog K325 Dodge 880 bushings
Inner Diameter 0.50"
Outer Diameter 1.13"
Length C 1.88"
Length D 1.26"
Length E 0.37"
Moog K408 regular A, B, and E body bushings
Outer Diameter 1.17"
Length C 1.88"
Length D 1.26"
Length E 0.37"
Moog K7103 offset A, B, and E body bushings
Inner Diameter 0.51"
Length C 1.70"
Length D 1.26"
Length E 0.28"
