best lifter option for an all crower valvetrain?
#1691894
10/29/14 02:10 PM
10/29/14 02:10 PM
Posts: 207 kauai
maxi333
kauai
been looking around and can't figure out which brand i trust or will work well with the setup i've got. any direction would be great, good quality lifters not sure if i trust crower anymore? I'm working with a '66 383, 32240 crower cam 260hdp grind .456/.477, 64770 crane 1.5 rocker arms and 64672 crane chromoly cup/ball pushrods 8.25" pretty mild setup i know but i'll be driving it 1300 miles in the next month. thanks all http://www.summitracing.com/parts/crn-64770-16http://www.summitracing.com/parts/crn-64672-16
1962 Chrysler 300 convertible 383/727 1970 Dodge A108 Boogie Van 318/727
Re: best lifter option for an all crower valvetrain?
[Re: Cab_Burge]
#1691896
10/29/14 03:30 PM
10/29/14 03:30 PM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
Crower now has a Hyd lifter with added cam oiling.Crower quality is as good as it gets.
Leave the gun.......take the Cannoli's....Mike
[Re: mike s]
#1691897
10/29/14 03:36 PM
10/29/14 03:36 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
I have used those lifters on 2 builds, no issues as of yet ... knock on wood ... the bad is they require shorter pushrods because they are basically built to fit the AMC application.
[Re: racerhog]
#1691901
10/31/14 12:13 AM
10/31/14 12:13 AM
Posts: 1,305 Lakewood, Colorado
herkamer
Lakewood, Colorado
Rhoads with the Super Lube groove. Even on a mild cam you can pick up some low end and mileage. Call Don at Ajax Auto Parts 303.420.3696 for the best price.
Matt 69 Dart Swinger 340 83 W350, Megasquirted with 46RH Old news: 72 Demon street/race mobile Latest: 70 Duster backhalf car and even more
[Re: herkamer]
#1691902
11/07/14 02:49 AM
11/07/14 02:49 AM
Posts: 207 kauai
maxi333
kauai
yeah broke the motor in and all was good until the crower lifters that were in it started to cause ticking, pulled them out and the majority of them were so stuck i couldn't get the snap clip out to clean them out. not sure if it was because the motor sat for some years before break in??
[Re: maxi333]
#1691903
11/07/14 11:14 PM
11/07/14 11:14 PM
Posts: 4,320 Prospect, PA
BSB67
Prospect, PA
You still don't seem to get how they are suppose to work.
[Re: BSB67]
#1691904
11/10/14 03:55 PM
11/10/14 03:55 PM
Posts: 207 kauai
maxi333
kauai
pretty sure i do bud, but even if i didn't comments like those don't help
[Re: BSB67]
#1691907
11/11/14 12:52 PM
11/11/14 12:52 PM
Posts: 207 kauai
maxi333
kauai
once again guy was looking for actual help, don't really need your idioms and at this point you could use it yourself... thanks to everyone else for the help ![](/ubbthreads/images/graemlins/smile.gif)
[Re: maxi333]
#1691908
11/11/14 10:58 PM
11/11/14 10:58 PM
BSB67
Prospect, PA
Okay, moving past not understanding how they work and moving to a replace solution, I would do what Cab said:
Give Dave Crower a call. I think he is still around. He will genuinely want to hear feed back about his product and any problems you are having. My guess is that even if you are unconvincing that the lift is at fault, he will likely still send you a new set at no cost.
Like Lew said, in so many words or less, everything at about the same price point is the same level of quality. The name on the box really does not matter. Sometimes you get lucky, sometimes you don't.
For you application, any supplier's inexpensive lifters should work.
