Upgrading 73 `Cuda style disc brakes #1691798
10/28/14 10:08 PM
10/28/14 10:08 PM
New Mexico
UCUDANT Online content OP
Troll Hunter
UCUDANT  Online Content OP
Troll Hunter
New Mexico
I will be swapping an E body from front drums to 73 Cuda disc brakes and want to upgrade the system some. It's for a 500hp small block street car
I'm thinking a minimum of drilled and slotted rotors. Would it be worth using reproduction caliper adapters for the larger C body discs?
Re: Upgrading 73 `Cuda style disc brakes [Re: UCUDANT] #1691799
10/28/14 10:19 PM
10/28/14 10:19 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
I would recommend any of Dr. Diff's kits and installing an adjustable proportioning valve.
I would highly advise against drilled rotors though, you will not need them for track use.
Here is a 13" rotor that Cass sells which recently showed up
Thanks Cass!
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Upgrading 73 `Cuda style disc brakes [Re: UCUDANT] #1691800
10/28/14 10:42 PM
10/28/14 10:42 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
If you're going to change rotors anyway I would upgrade to the C-body rotors for sure.
Sheldon
Re: Upgrading 73 `Cuda style disc brakes [Re: RylisPro] #1691801
10/28/14 10:59 PM
10/28/14 10:59 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Another tip is to pay attention to the direction of the internal vanes the rotors have and to ignore the direction of the slots
I checked the one installed on my car and they go straight up and down while this new rotor I have is effectively a driver side rotor
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Upgrading 73 `Cuda style disc brakes [Re: RUNCHARGER] #1691802
10/29/14 09:41 AM
10/29/14 09:41 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
I've got 11.75" / 1.25" thick '73 Chrysler rotors on my '73 Dart.
Shimmed the original adapter with a simple washer to the correct caliper alignment and made a colar for the spindle to be able to use the stock '73 C-body outer bearing.
Sheldon
Are those C-body rotors in your pic? They don't look any thicker than 1" to me.
Re: Upgrading 73 `Cuda style disc brakes [Re: BigBlockMopar] #1691803
10/29/14 11:25 PM
10/29/14 11:25 PM
upper So. CA
N
ntsqd Offline
ntsqd  Offline
N
upper So. CA
Rotor thickness is really just a rough idea of how well it will radiate heat with lots of other factors involved.
Rotor diameter is where better stopping power comes from. Bigger OD = more brake torque from the same hydraulics.
I used to swerve around my hallucinations, now I drive right thru them.
Re: Upgrading 73 `Cuda style disc brakes [Re: BigBlockMopar] #1691804
10/29/14 11:29 PM
10/29/14 11:29 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
You think those are only 1" thick? The studs are 1/2" dia, compare those to the thickness. Sure looks like 1 1/4" thick rotor to me.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Upgrading 73 `Cuda style disc brakes [Re: amxautox] #1691805
10/30/14 12:17 AM
10/30/14 12:17 AM
New Mexico
Troll Hunter
Troll Hunter
New Mexico
After reading the above responses I started cross referencing wheel bearing PN's and it does appear the outer bearing is different.
What is the best solution for the wheel bearing to adapt the 73 E body spindle and the C body (73 and up?) rotor?Thanks for you input.
I'm already cleaning and prepping parts
THANKS
Re: Upgrading 73 `Cuda style disc brakes [Re: UCUDANT] #1691806
10/30/14 01:58 PM
10/30/14 01:58 PM
AndyF Offline
AndyF  Offline
There isn't really a clean way to hang a C body rotor on an E body spindle. You have to use spacers and hope they don't spin. I looked into having Timkin produce a conversion bearing but the cost was way too high for me to front.
Re: Upgrading 73 `Cuda style disc brakes [Re: AndyF] #1691807
10/30/14 02:51 PM
10/30/14 02:51 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I make outer bearing adapters for mounting '73 and newer C-body rotors on '73 and newer A/B/E/F/M/J/R body knuckles. They are no more likely to spin than the bearing itself.
You could also use '69-'72 C-body rotors, bearings and seals. These fit '72 and earlier B/E body knuckles out of the box.
If you install an A13 inner bearing and race, the earlier C-body rotors will fit '73 and newer A/B/E/F/M/J/R body knuckles without an adapter. I never looked into a seal for that combination, however.
Re: Upgrading 73 `Cuda style disc brakes [Re: DoctorDiff] #1691808
10/30/14 09:32 PM
10/30/14 09:32 PM
New Mexico
Troll Hunter
Troll Hunter
New Mexico
Are they the 2 piece rotor/hub?
So the earlier C body outer bearing is the same as the 73 and up E body but it's inner is different?
Re: Upgrading 73 `Cuda style disc brakes [Re: UCUDANT] #1691809
10/31/14 12:06 AM
10/31/14 12:06 AM
IN
ahy Offline
ahy  Offline
IN
The later 11.75" A/B rotor which fits (from memory) your spindles is a pretty stout piece. Suggest you use that. A good quality replacement rotor (parts store) should be fine. Newer formulation high po brake pads do not "out gas" much once broken in and I don't think slots or holes help much... and holes can start cracks.
Re: Upgrading 73 `Cuda style disc brakes [Re: UCUDANT] #1691810
10/31/14 12:49 AM
10/31/14 12:49 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Replacement '68-'72 C-body rotors are identical to the unicast '73 and newer version except for the bearing bore sizes.
The early C-body rotor will bolt to the early B/E body spindles using the original/same bearings.
Re: Upgrading 73 `Cuda style disc brakes [Re: DoctorDiff] #1691811
10/31/14 04:30 PM
10/31/14 04:30 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
Dr. Diff -- For the 72-older spindles, using the 72-older larger C-body discs (and thus the 72-older smaller bearings, etc), are there special adapters needed for the calipers? Also, could light weight aluminum calipers, such as Wilwood (which part number?), be fitted accordingly? Mine is still 72-older spindles and stock calipers (actually, 72 calipers).
Re: Upgrading 73 `Cuda style disc brakes [Re: Mopar Mitch] #1691812
10/31/14 07:19 PM
10/31/14 07:19 PM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
Why not just us a C-Body spindle?
Re: Upgrading 73 `Cuda style disc brakes [Re: DoctorDiff] #1691813
10/31/14 07:22 PM
10/31/14 07:22 PM
central CT
cudazappa Offline
cudazappa  Offline
central CT
What's the diameter of these rotors? Also, what calipers would you use in this case?
This is a really cool finding in this thread!
1971 Challenger
Re: Upgrading 73 `Cuda style disc brakes [Re: cudazappa] #1691814
10/31/14 10:51 PM
10/31/14 10:51 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
C-body rotors measure 11.75" x 1.25".
I make brackets that mate first generation Viper calipers, C-body rotors and B/E body drum knuckles.
Herman, who posted earlier in this thread, installed C-body rotors and pin type calipers on B-body knuckles using B-body 11.75" pin type caliper brackets.
Re: Upgrading 73 `Cuda style disc brakes [Re: DoctorDiff] #1691815
11/04/14 11:39 PM
11/04/14 11:39 PM
New Mexico
Troll Hunter
Troll Hunter
New Mexico
On an E body? This is one that that tech editors disagree on
At this point I'm still not certain, there are allot of options. I'm considering all that it en-tales Is the extra 'close to an inch" of brake worth the effort? This is really all for a street panic stop
Dr Diff please PM me (or reply here) enough info so I can order your outer bearing (73 Cuda spindle to later C body rotors) adapter, once I locate the C caliper adapters. Thanks to you and everyone who provide parts we in the hobby truly need
Re: Upgrading 73 `Cuda style disc brakes [Re: UCUDANT] #1691816
11/05/14 06:58 AM
11/05/14 06:58 AM
The Netherlands
The Netherlands
No E-body, but A-body, and using the stock '73 A-body knuckles.
An outer bearing spacer on the spindle and 2 washers behind the caliperbrackets was all I needed.
Oh and maybe the seals in the rear of the rotors which came from a GM transmission.
The C-body rotor swap also made the tracking width better, which is dearly needed on an A-body and wider wheels.
Re: Upgrading 73 `Cuda style disc brakes [Re: BigBlockMopar] #1691817
11/05/14 09:47 AM
11/05/14 09:47 AM
New Mexico
Troll Hunter
Troll Hunter
New Mexico
So the C body rotor changes track width?
