Big Block Heads - Water Passages Question #1691766
10/28/14 08:40 PM
10/28/14 08:40 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
Trying to help CORONETGIRL's Dad with his cracked cylinder head on his '61 361 engine. The car has 324 heads and one head has a crack in the chamber by the spark plug hole. Looks to be at least 1/2 inches long.
I don't feel that welding it would be a viable fix. Not sure if you can stitch weld it or not.
My suggestion was to go with the newer style 516 heads. They have the same valve sizes and chamber CC but would need modern valve train (the 324 has flat rocker pedestals).
But we are seriously confused. The 324 head has 2 additional approx 1/2 inch round water passages in between the intake valves the the 516 and 906 heads don't have. From the look of the head gasket, does appear that there was water flow through these holes. Cannot find a new head gasket that has holes for the additional water passages.
So I figured that only the older heads had the additional passages, but then I noticed that my 452 heads also have those additional holes but they are not round (see picture).
So the question on the table is what are the additional holes for and is there supposed to be water flow through them or not? Is it safe to use a 516 head without the additional holes? I figured worse comes to worse I can drill the additional holes in the 516 head and the head gaskets.
Any ideas?
Re: Big Block Heads - Water Passages Question [Re: markz528] #1691767
10/28/14 10:44 PM
10/28/14 10:44 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
We put my 516s on the kids 62 413 about 4 years ago.It still has no problems.Used Felpro 1039 gaskets I believe.Never gets over 190 even on the hottest days.His heads were perfect but mine had big valves and some more work.Rocky
Chrysler Firepower
Re: Big Block Heads - Water Passages Question [Re: therocks] #1691768
10/29/14 05:20 AM
10/29/14 05:20 AM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
email or pm me I have a pair of 324's
Leave the gun.......take the Cannoli's....Mike
Re: Big Block Heads - Water Passages Question [Re: markz528] #1691769
11/11/14 07:15 PM
11/11/14 07:15 PM
Somewhere I Belong
coronetgirl Offline
Rotten to the core
coronetgirl  Offline
Rotten to the core
Somewhere I Belong
Thanks Mark and Mike for your help.
Good friendships are built on a foundation of alcohol, sarcasm, inappropriateness, and shenanigans.
Re: Big Block Heads - Water Passages Question UPDATE [Re: markz528] #1691770
01/05/15 08:45 AM
01/05/15 08:45 AM
Somewhere I Belong
coronetgirl Offline
Rotten to the core
coronetgirl  Offline
Rotten to the core
Somewhere I Belong
Dad has the heads on the car and all is right with the world again. A huge thanks to Mark and Mike for helping us out.
