Advantages to Titanium vs Stainless?? #1691565
10/28/14 12:33 PM
10/28/14 12:33 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Is titanium valves really worth the extra $1000ish dollars?
Lets hear the pros n cons
Re: Advantages to Titanium vs Stainless?? [Re: Jeepmon] #1691566
10/28/14 01:37 PM
10/28/14 01:37 PM
It depends on the intended RPM range of the motor, if you want to rev it past 8000 RPM then go with the titianum, if not don't
Re: Advantages to Titanium vs Stainless?? [Re: Cab_Burge] #1691567
10/28/14 01:40 PM
10/28/14 01:40 PM
Las Vegas
Al_Alguire Online laugh2
Las Vegas
Well IMO it IS worth the extra money. Saving weight in the valvetrain is always beneficial. Just my
Re: Advantages to Titanium vs Stainless?? [Re: Al_Alguire] #1691568
10/28/14 01:50 PM
10/28/14 01:50 PM
Arlington, Tx.
BJS racing Offline
BJS racing  Offline
Arlington, Tx.
And they sound way cooler! LOL.
Back in the swing of things at Painless again! Great to be back!
Re: Advantages to Titanium vs Stainless?? [Re: Jeepmon] #1691569
10/28/14 02:09 PM
10/28/14 02:09 PM
AndyF Offline
AndyF  Offline
On a serious race engine you'll need the Ti valves. The Ti valves are actually cheaper on a race engine since you won't have to replace valve springs as often. All depends on the cam profile and the RPM that the engine turns.
Re: Advantages to Titanium vs Stainless?? [Re: AndyF] #1691570
10/28/14 02:20 PM
10/28/14 02:20 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
I can appreciate that the titanium is a lighter valve, therefore you can spin the motor a little faster and it will save on valve springs.. So I guess the question I have... is spending the extra coin now really worth it, once my butt gets strapped into the seat?
Also, I was reading elsewhere that an inconel (or some super alloy) valve is recommended for the exhaust... since I'm more in favor of a bulletproof motorover squeezing out every last pony.. wouldnt I want to get a stronger/harder valve and not worry so much about breakage?
Re: Advantages to Titanium vs Stainless?? [Re: Jeepmon] #1691571
10/28/14 03:30 PM
10/28/14 03:30 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I would spend the money on a longer stroke to keep the RPM down so I don't need Ti valves
Re: Advantages to Titanium vs Stainless?? [Re: HotRodDave] #1691572
10/28/14 03:55 PM
10/28/14 03:55 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Its for a B-1 original 572 motor.. anywhere from 900hp and up... spinning at no more than 7500
Re: Advantages to Titanium vs Stainless?? [Re: Jeepmon] #1691573
10/28/14 05:10 PM
10/28/14 05:10 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
Inconel valves are for turbo apps where the exhaust temps are much higher than naturally aspirated.
Re: Advantages to Titanium vs Stainless?? [Re: Jeepmon] #1691574
10/28/14 06:17 PM
10/28/14 06:17 PM
AndyF Offline
AndyF  Offline
Depends on lift. I only spin my 514 to 7500 rpm but I'm close to .900 lift so the recommendation was to use Ti on the intakes.
Re: Advantages to Titanium vs Stainless?? [Re: TheOtherDodge] #1691575
10/28/14 08:22 PM
10/28/14 08:22 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
I didnt know that.. thanks
Re: Advantages to Titanium vs Stainless?? [Re: AndyF] #1691576
10/28/14 08:24 PM
10/28/14 08:24 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
We're also at .900 lift.. and after talking with my engine guy today.. He is solid on stainless steel for my application.. So I guess that means we are for sure going that route..
Re: Advantages to Titanium vs Stainless?? [Re: Jeepmon] #1691577
10/28/14 08:28 PM
10/28/14 08:28 PM
dogdays Offline
dogdays  Offline
Rifle drill the stems.
Re: Advantages to Titanium vs Stainless?? [Re: Jeepmon] #1691578
10/28/14 08:30 PM
10/28/14 08:30 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
The main difference is, with the 2.30 valve, it is harder to control it with the heavier valve. A valve not controlled, is a bad thing so you need to run higher spring pressures. That's the trade off. I've used both and don't believe there's a performance gain, just piece of mind. I hope it runs to your satisfaction this time Don.
Re: Advantages to Titanium vs Stainless?? [Re: camastomcat] #1691579
10/28/14 09:24 PM
10/28/14 09:24 PM
Washington
madscientist Offline
Washington
Head diameter, stem diameter, valve length, ramp speed and RPM are just a few of the factors in deciding on valve material. I'm not going to say I am smarter than David Reher (I'm not) but he and I agree that Ti is the only consideration for most ANY engine of today's geometry. It's just not worth messing with steel. Today, bracket engines are using lobes that are faster then Pro Stock of only 10 years ago. You can order lobes today that are so close to PS that it is unthinkable. Yet, guys continue to try and cut corners on valves.
I wouldn't consider steel.
BTW, it's one of the few things I wholeheartedly agree with DR. Not that he cares.................
Re: Advantages to Titanium vs Stainless?? [Re: madscientist] #1691580
10/29/14 01:25 AM
10/29/14 01:25 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
What kind of lifespan does a ti valve and beryllium seat have?
Kevin
Re: Advantages to Titanium vs Stainless?? [Re: Twostick] #1691581
10/29/14 02:52 PM
10/29/14 02:52 PM
Washington
Washington
I stopped using BC seats back in about 2005. I started using Nickel Boron (IIRC). They machine much easier. And last just as long. How long they last is hard to determine. Too many unknown factors. BUT...Ti will not last as long using CI or ANY brand of hard seat out there.
Re: Advantages to Titanium vs Stainless?? [Re: Jeepmon] #1691582
10/29/14 04:20 PM
10/29/14 04:20 PM
ky
68roadrunner Offline
ky
what about the wear on the valve face, and this hard coating they are putting on them?
Re: Advantages to Titanium vs Stainless?? [Re: 68roadrunner] #1691583
10/29/14 04:45 PM
10/29/14 04:45 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
You're going to be right on border with a Stainless intake valve that is 2.300" in diameter and 11/32. I would go Ti if you are going to spin it over 7000.
Re: Advantages to Titanium vs Stainless?? [Re: Biginchmopar] #1691584
10/30/14 02:28 PM
10/30/14 02:28 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Thanks again everyone for your info... I spoke with the engine builder again yesterday.. Straight up told him I wanted to break the bank and get the titanium valves...
He flat out rejected that idea and used that polite "In all due respect" phrase... which basically means he refuses to spend the extra money and once again said I should save the money or upgrade to better heads and then get the exotic valves..
I guess that means he doesnt like B1 Original heads... but then he's a high horsepower, heads up racer...
