Re: Advantages to Titanium vs Stainless??
[Re: HotRodDave]
#1691572
10/28/14 03:55 PM
10/28/14 03:55 PM
Posts: 8,094 Sunnyvale, CA
Jeepmon
Sunnyvale, CA
I would spend the money on a longer stroke to keep the RPM down so I don't need Ti valves
Its for a B-1 original 572 motor.. anywhere from 900hp and up... spinning at no more than 7500
[Re: TheOtherDodge]
#1691575
10/28/14 08:22 PM
10/28/14 08:22 PM
Jeepmon
Sunnyvale, CA
Inconel valves are for turbo apps where the exhaust temps are much higher than naturally aspirated.
I didnt know that.. thanks
[Re: AndyF]
#1691576
10/28/14 08:24 PM
10/28/14 08:24 PM
Jeepmon
Sunnyvale, CA
Depends on lift. I only spin my 514 to 7500 rpm but I'm close to .900 lift so the recommendation was to use Ti on the intakes.
We're also at .900 lift.. and after talking with my engine guy today.. He is solid on stainless steel for my application.. So I guess that means we are for sure going that route..
[Re: Jeepmon]
#1691577
10/28/14 08:28 PM
10/28/14 08:28 PM
dogdays
[Re: Jeepmon]
#1691578
10/28/14 08:30 PM
10/28/14 08:30 PM
Posts: 2,128 Salt Lake City
camastomcat
Salt Lake City
The main difference is, with the 2.30 valve, it is harder to control it with the heavier valve. A valve not controlled, is a bad thing so you need to run higher spring pressures. That's the trade off. I've used both and don't believe there's a performance gain, just piece of mind. I hope it runs to your satisfaction this time Don.
[Re: camastomcat]
#1691579
10/28/14 09:24 PM
10/28/14 09:24 PM
Posts: 4,457 Washington
madscientist
Washington
Head diameter, stem diameter, valve length, ramp speed and RPM are just a few of the factors in deciding on valve material. I'm not going to say I am smarter than David Reher (I'm not) but he and I agree that Ti is the only consideration for most ANY engine of today's geometry. It's just not worth messing with steel. Today, bracket engines are using lobes that are faster then Pro Stock of only 10 years ago. You can order lobes today that are so close to PS that it is unthinkable. Yet, guys continue to try and cut corners on valves.
I wouldn't consider steel.
BTW, it's one of the few things I wholeheartedly agree with DR. Not that he cares.................
[Re: Twostick]
#1691581
10/29/14 02:52 PM
10/29/14 02:52 PM
madscientist
Washington
I stopped using BC seats back in about 2005. I started using Nickel Boron (IIRC). They machine much easier. And last just as long. How long they last is hard to determine. Too many unknown factors. BUT...Ti will not last as long using CI or ANY brand of hard seat out there.
[Re: Biginchmopar]
#1691584
10/30/14 02:28 PM
10/30/14 02:28 PM
Jeepmon
Sunnyvale, CA
Thanks again everyone for your info... I spoke with the engine builder again yesterday.. Straight up told him I wanted to break the bank and get the titanium valves... He flat out rejected that idea and used that polite "In all due respect" phrase... which basically means he refuses to spend the extra money and once again said I should save the money or upgrade to better heads and then get the exotic valves.. I guess that means he doesnt like B1 Original heads... but then he's a high horsepower, heads up racer... ![](/ubbthreads/images/graemlins/shock.gif)
