72 truck frame under a 78? #1691487
10/28/14 12:05 AM
10/28/14 12:05 AM
north carolina
tyler_mccoy85 Offline OP
north carolina
Will a 1972 d100 frame fit under a 1978 d150se with no issues??
Re: 72 truck frame under a 78? [Re: tyler_mccoy85] #1691488
10/28/14 01:12 AM
10/28/14 01:12 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
And the final answer is: Probably!
72 being the 1st year of a new design some things are 72 specific, weather or not those specific things will effect a frame swap are in question. I suspect the basic frame will swap, providing both trucks are the same cab/box configuration.
There may be issues with things like fuel tanks, as far as I know, 72 were all in cab fuel tanks, so mounting a frame mount tank might be a challenge. Wiring will be different. Brakes may or may not be an issue. Body and cab mounts might be slightly different (especially the rad support mounts). Most other stuff should swap out as units, but may differ part to part. Hope this answers your questions.
Gene
Re: 72 truck frame under a 78? [Re: poorboy] #1691489
10/28/14 01:39 AM
10/28/14 01:39 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
radiator support mounts possibly I swapped beds on one once & the front bed mounts were a different height or something IIRC
Re: 72 truck frame under a 78? [Re: BulletBob] #1691490
10/28/14 02:36 AM
10/28/14 02:36 AM
fredericksburg virginia
mopwrd340 Offline
mopwrd340  Offline
I think the bed mounts are different between 2 and 4WD trucks .
Re: 72 truck frame under a 78? [Re: mopwrd340] #1691491
10/28/14 11:38 PM
10/28/14 11:38 PM
north carolina
north carolina
Well the 72 is a 2wd and the 78 is a 2wd. The 72 frame is bare and we were going to have someone do some suspension and steering upgrades to it. Then it will go to the body shop and the frame and body will be reunited with brand new steering and suspension and a 5.7 hemi crate motor. Not to worried about wiring because from experience the dodge wiring sucks so we always retrofit a wiring kit.
Re: 72 truck frame under a 78? [Re: tyler_mccoy85] #1691492
10/29/14 03:00 AM
10/29/14 03:00 AM
woodcrest, CA
magnum440d100 Offline
woodcrest, CA
Having a 72 and trying to use parts from a 77, I can tell you that some stuff is definitely different.
Comes to mind off the top of my head:
Motor mount pads. 72 are flatter/prone to crack. Mine are cracked on my 72, the 77's are taller and have an extra "leg" for support.
Rear bump stop brackets. IIRC, 77 is larger bolt pattern but look identical.
If your 78 had an in frame fuel tank, the brackets/crossmember may be just a hair different.
Emergency brake lines run through the crossmember on the 72, 78 will have them on the drivers side below the framerail.
Sway bar is different between the 2. The 78 may have rivets where the bar mounts on the frame under the core support crossmember and vise versa.
Brake lines are routes different. 72, proportioning valve is horizontal and I believe outside the frame. 78 should be verticals and in the frame. I may be confused though, but there is a difference.
I believe that is it. I can't think of any other differences.
Re: 72 truck frame under a 78? [Re: magnum440d100] #1691493
10/29/14 04:59 AM
10/29/14 04:59 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
72-93 are virtually the same
Re: 72 truck frame under a 78? [Re: 76dodgeboy] #1691494
10/29/14 05:13 AM
10/29/14 05:13 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Fuel tank for 72 was in cab only. Brakes were drum in 72 front and rear. Beds mount the same 2 and 4wd. E brake is different. Wheel bolt pattern for 2wd is 5x4.5" till 84.
Wheel bolt pattern are as followed
W series-PowerWagon-4wd
72-74 5x5.5"
Late 74-79 5x4.5"
80 up 5x5.5"
D Series-2wd
72-84 5x4.5"
85 up 5x5.5"
Another way to remember the 4wd Bolt pattern is The full-time is the only 4.5" bolt pattern.
If you plan on running the saddle tank swap the required crossmembers needed.
Sway bar was 1 yr only also in 72
Re: 72 truck frame under a 78? [Re: 76dodgeboy] #1691495
10/29/14 05:20 AM
10/29/14 05:20 AM
Laveen, Arizona
GTSDart340 Offline
GTSDart340  Offline
Laveen, Arizona
My 72 D200 has discs in front....
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
Re: 72 truck frame under a 78? [Re: GTSDart340] #1691496
10/29/14 05:49 AM
10/29/14 05:49 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Most likely converted or mid late year upgrade? Ive always heard 72 was drum. Know of one for sale even
Re: 72 truck frame under a 78? [Re: 76dodgeboy] #1691497
10/29/14 05:57 AM
10/29/14 05:57 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
D100
RAYBESTOS Part # 1924R {#101924, 1924} Professional Grade; Outside Diameter 12.62" / 5 Bolts / Not Finned
Front
$80.99
D200
RAYBESTOS Part # 1982 Professional Grade; Outside Diameter 14" / 8 Bolts / Not Finned
Front; 12" X 2-1/2" Brakes [Wholesaler Closeout -- 30 Day Warranty]
$25.34
They also show a Rotor for both
Re: 72 truck frame under a 78? [Re: 76dodgeboy] #1691498
10/29/14 07:45 AM
10/29/14 07:45 AM
Laveen, Arizona
GTSDart340 Offline
GTSDart340  Offline
Laveen, Arizona
My truck is a later build, not sure on the date, but the partial Vin is D24BF2U581***.
Re: 72 truck frame under a 78? [Re: 76dodgeboy] #1691499
10/29/14 03:20 PM
10/29/14 03:20 PM
Des Moines IA
Soopernaut Offline
Soopernaut  Offline
Des Moines IA
Discs were optional in 72 but they use some 1 year only parts.
1970 Dodge d100/eventually going on a 77 D100 frame
Re: 72 truck frame under a 78? [Re: 76dodgeboy] #1691500
10/31/14 02:08 AM
10/31/14 02:08 AM
north carolina
north carolina
Thanks for the information. This should get us on track.
