Re: 440 block with no main caps..493 stroker..have ?'s
[Re: JoesMopar]
#1691474
10/28/14 02:00 AM
10/28/14 02:00 AM
RapidRobert
Kind of WAG here but I'm thinking stud the mains/aftermarket steel caps/line hone or bore (talk to your machinist)
[Re: JoesMopar]
#1691475
10/28/14 02:22 AM
10/28/14 02:22 AM
Posts: 171 Las Vegas, NV
chargerbr549
Las Vegas, NV
I am going by memory but an option that I thought might work is to find some 400 main caps and have them align bored on the 440 block, I have never tried this but it looks like it might work. I believe the 400 caps will fit the 440 registers and also the 400 bearing notch is very deep and there might be enough of it left after the line bore to where you wouldn't have to renotch the cap for the bearing tang. Another area to look at is the thrust main cap if it will closely match the thrust surface in the block, just a thought.
Like JohnRR said go with the 4.25 stroke with big block chevy rod journal it's almost a drop in with virtually no grinding depending on what rod you use whereas the 4.15 stroke with big block chrysler rods usually needs grinding for clearance plus you have more weight and less cubic inches.
[Re: JoesMopar]
#1691477
10/28/14 11:49 AM
10/28/14 11:49 AM
Posts: 12,216 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Ohio Crank is a good source for quality stroker kits.
Master, again and still
[Re: JoesMopar]
#1691481
10/28/14 10:06 PM
10/28/14 10:06 PM
Posts: 6,988 Warren, MI
Jerry
Warren, MI
using the 400 caps and boring them out, while dimensionally will work, is not the best idea. on a big block you definitely want to use a girdle if your stroking. and a block missing caps is no big deal, your going to want aftermarket caps anyway.
aluminum acts like a shock absorber in your bottom end to absorb some vibration. that being said you do want to back it up with a steel girdle.
the BCR products girdle kits we build and sell use arp studs for good clamping of the mains, and then the girdle is bolted down to the oil pan rail with its own studs and nuts, and then to the caps with its own studs and nuts. we don't use the main studs to clamp the girdle as well. this creates too much stack up on the stud. we also cnc the girdle plate and nuts on the oil pan rail are countered bored into the plate. to bolt the oil pan on we supply a second nut, so if you ever want to remove just the pan you can. all of our components are made in the USA including our materials.
[Re: JoesMopar]
#1691485
10/29/14 01:42 AM
10/29/14 01:42 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Thanks for the info and pic. I absolutely love your '63
Thank you for the kind words. Ron
