Re: TTI headers for a hemi e body
[Re: Uncle Barry]
#1691442
10/28/14 10:31 AM
10/28/14 10:31 AM
Posts: 13,360 Marion, South Carolina [><]
an8sec70cuda
I have the TTI 2 1/4" primary 4" collector headers on my 572" hemi in my '70 cuda. The front end is all stock stuff, except for the motorplate. Had to cut part of the original motor mount bracket off the K frame on the driver's side only. Manual steering and manual brakes. I only had to clearance one tube on the passenger's side to clear the torsion bar. Other than that, they fit great!
Depending on how your motor is built, the 2 1/8" headers will likely be plenty big. They will probably make for a better street/strip header since they will make more lowend torque, especially if your hemi is fairly mild. Not to mention fitting better. I went w/ the big ones b/c I wanted every last bit of power I could get (over 800 on just the motor, then there's the nitrous) and I can put up w/ a lot on the street.
[Re: RUNCHARGER]
#1691447
11/03/14 02:56 PM
11/03/14 02:56 PM
Posts: 73 Toronto,Canada
wkeggenhoff
Toronto,Canada
When I installed my 528 a few years back in a 69 charger spoke with Tim Banning @ FHO and he said 2 1/8 is all I would ever need on a street car. There were a tight enough fit at that
69 dodge charger,528 Hemi,Keisler TKO 5spd, Mosier 60 rear end
[Re: wkeggenhoff]
#1691448
11/04/14 03:29 AM
11/04/14 03:29 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I am running to quick fuel (holley's) on my 572 with the stageV intake, Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
