BBM Pistons for B1 heads work with conventional heads? #1691185
10/27/14 11:37 AM
10/27/14 11:37 AM
Boston, MA
johnnyd Offline OP
johnnyd  Offline OP
Boston, MA
Hi All,
Generally speaking, I know that pistons designed to work with conventional BBM heads like (Indy 440-1) need some valve pocket machining to work with B1 original heads. Can anyone tell me about the opposite? Will pistons designed to run on a BBM B1 original headed BBM work with a 440-1 head or do they also need machining? I'm thinking of cam lifts less than .700 .
Thanks!
Re: BBM Pistons for B1 heads work with conventional heads? [Re: johnnyd] #1691186
10/27/14 01:01 PM
10/27/14 01:01 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
i would say no, unless you have a very low lift <.600 or the piston was way down in the hole.
Joe
Without Data, you’re just another guy with an opinion.
Re: BBM Pistons for B1 heads work with conventional heads? [Re: sr4440] #1691187
10/27/14 03:13 PM
10/27/14 03:13 PM
Apollo, PA.
B1MAXX Online content
B1MAXX  Online Content
Apollo, PA.
Joe
they are in two different locations. It can be cut though.
Re: BBM Pistons for B1 heads work with conventional heads? [Re: B1MAXX] #1691188
10/27/14 04:28 PM
10/27/14 04:28 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
B1 exhaust valve is a 1.76
Re: BBM Pistons for B1 heads work with conventional heads? [Re: johnnyd] #1691189
11/10/14 04:08 PM
11/10/14 04:08 PM
Boston, MA
johnnyd Offline OP
johnnyd  Offline OP
Boston, MA
I emailed Indy and never heard back.
I also emailed Koffel and heard back from them. They said that the B1 piston will work with a conventional head- just need to account for the compression ratio being lower from the increased valve reliefs in the B1 piston over a conventional headed piston relief.
Re: BBM Pistons for B1 heads work with conventional heads? [Re: johnnyd] #1691190
11/10/14 07:07 PM
11/10/14 07:07 PM
gregsdart Offline
gregsdart  Offline
I have heard of this before. If the piston is B1 based, then there will be enough room for the rings and the valve reliefs, as the B1 is a tighter situation. If the piston is based on a standard wedge head, there might be problems.
I wouldn't buy anything though without having an engine builder measuring it for the cam and heads you want to run.
Re: BBM Pistons for B1 heads work with conventional heads? [Re: johnnyd] #1691191
11/10/14 08:19 PM
11/10/14 08:19 PM
Utah
dragnduster Offline
dragnduster  Offline
Utah
Thanks for the update, I am going to put my Victor heads on a B-1 based 512" lowdeck short block and I was hoping not to have to change pistons.
I will definitely check p/v clearance to make sure though.
