B1 timing #1691050
10/26/14 11:08 PM
10/26/14 11:08 PM
On the parachute mount
N
n20mstr Offline OP
n20mstr  Offline OP
N
Where are you running you timing ?
....BAD A$$ STREET CAR.....
Re: B1 timing [Re: n20mstr] #1691051
10/26/14 11:12 PM
10/26/14 11:12 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
i was at 34
Re: B1 timing [Re: n20mstr] #1691052
10/26/14 11:20 PM
10/26/14 11:20 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
How big is the engine?
Re: B1 timing [Re: camastomcat] #1691053
10/27/14 10:33 AM
10/27/14 10:33 AM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
The ones I have done all ended up between 32-34.
One day I will have something cool here.
Re: B1 timing [Re: sdaurity] #1691054
10/27/14 11:20 AM
10/27/14 11:20 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I 've read that 70* is a little tooooo much
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: B1 timing [Re: hemi-itis] #1691055
10/27/14 03:55 PM
10/27/14 03:55 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
We made max power and 36.5 on the 525
Re: B1 timing [Re: hemi-itis] #1691056
10/27/14 04:36 PM
10/27/14 04:36 PM
Staten Island N.Y.
Dap Offline
Dap  Offline
Staten Island N.Y.
I have to laugh at that one.
PRH446
10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
Re: B1 timing [Re: Dap] #1691057
10/27/14 05:14 PM
10/27/14 05:14 PM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
My old 526" B1 motor made best power at 42 deg.
Re: B1 timing [Re: STEFF] #1691058
10/27/14 08:52 PM
10/27/14 08:52 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
what compression and fuel are you using
1.39 9.85 - 137 mph
Re: B1 timing [Re: Ari440] #1691059
10/27/14 10:43 PM
10/27/14 10:43 PM
Arizona
Chris'sBarracuda Offline
Arizona
36*-38* depending on the air..
Never see "Sea Level" here or in Vegas..
Chris..
Re: B1 timing [Re: camastomcat] #1691060
10/27/14 11:27 PM
10/27/14 11:27 PM
N
n20mstr Offline OP
n20mstr  Offline OP
N
Small
Re: B1 timing [Re: Ari440] #1691061
10/27/14 11:28 PM
10/27/14 11:28 PM
N
n20mstr Offline OP
n20mstr  Offline OP
N
Should be right at 13. Using renegade 120 nitrous fuel
Re: B1 timing [Re: n20mstr] #1691062
10/28/14 12:18 AM
10/28/14 12:18 AM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Small
Well.....on my 471 B1 I ran 34-35 degrees and my 572 B1 32 degrees was best. Small doesn't really tell anyone much. No cam info, not much compression so.....
Re: B1 timing [Re: n20mstr] #1691063
10/28/14 11:11 AM
10/28/14 11:11 AM
Staten Island N.Y.
Dap Offline
Dap  Offline
Staten Island N.Y.
Sounds like a question for Monte. How much are you planning on spraying it with?
PRH446
Re: B1 timing [Re: Dap] #1691064
10/28/14 11:17 AM
10/28/14 11:17 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
What cc's are the chambers? Are they softened or no? Dome or flat top piston? I would start at 34 and read the plugs correctly. The B1 has a fast chamber so if you are spraying 350+, I would have the chambers softened.
Re: B1 timing [Re: Dap] #1691065
10/28/14 07:29 PM
10/28/14 07:29 PM
N
n20mstr Offline OP
n20mstr  Offline OP
N
As much as it takes
Re: B1 timing [Re: fbs63] #1691066
10/28/14 07:31 PM
10/28/14 07:31 PM
N
n20mstr Offline OP
n20mstr  Offline OP
N
Already done, and yes flat top
Re: B1 timing [Re: n20mstr] #1691067
10/28/14 08:47 PM
10/28/14 08:47 PM
Staten Island N.Y.
Dap Offline
Dap  Offline
Staten Island N.Y.
As much as it takes
I should have known better than to ask that
PRH446
