Extra holes on A12 LH inner fender?? #1690341
10/25/14 12:01 PM
10/25/14 12:01 PM
Virginia
HemiStan Offline OP
HemiStan  Offline OP
Virginia
Are the two holes that are drilled above the LH shock tower correct for something or do I need to weld them up? I am not referring to the two holes for the fender tag, but if you look at the photo, they are further back on the inner fender above the shock tower. The car is an A12 Super Bee if it matters.
Thanks.
Stan
Re: Extra holes on A12 LH inner fender?? [Re: HemiStan] #1690342
10/25/14 12:14 PM
10/25/14 12:14 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Hey Stan, don't fill them yet! I'm pretty sure they are original. I'll get in touch with the new owner of my A12 Bee and have him double check.
Re: Extra holes on A12 LH inner fender?? [Re: 70440+6bbl] #1690343
10/25/14 12:25 PM
10/25/14 12:25 PM
Az
69hemibeep Offline
69hemibeep  Offline
Az
Those are from the factory leave them alone
1969 Hemi Roadrunner 2nd owner
Re: Extra holes on A12 LH inner fender?? [Re: 69hemibeep] #1690344
10/25/14 01:42 PM
10/25/14 01:42 PM
DFW
68RRFlyer Offline
68RRFlyer  Offline
DFW
Stan,
Notice that they are around the circumference of the spot welds for the inner fender shock tower brace on the underside. The holes don't go all the way through, so I'm not sure exactly what they were used for. Possibly something for alignment of the panels during assembly??
Leave them there. They are stock for all B-Body cars that I'm aware of. I checked my A12 Bee to verify they are there (thanks for the heads up James!!! ) and they are. I have also seen them on several 69 Chargers I've owned. The other three "dimples" I believe are for A/C line bracket hold downs.
Cheers
Re: Extra holes on A12 LH inner fender?? [Re: 68RRFlyer] #1690345
10/25/14 05:22 PM
10/25/14 05:22 PM
Virginia
HemiStan Offline OP
HemiStan  Offline OP
Virginia
Gentlemen, thanks for the info. I appreciate it.
Dave: I did notice that they looked "factory". It looks like the were drilled from the bottom side before the shock brace was welded in place.
James: Have you checked out the progress of the Bee in the thread I have going in the "Restoration" forum? It has been a loooong road but it is finally coming together.
Stan
Re: Extra holes on A12 LH inner fender?? [Re: HemiStan] #1690346
10/26/14 12:59 AM
10/26/14 12:59 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The only think I can think of that would have bolted down in that area would be the servo for cruise control. I can't ever remember seeing those holes there on any of the 69 B bodies I have owned.
Re: Extra holes on A12 LH inner fender?? [Re: JohnRR] #1690347
10/26/14 11:33 AM
10/26/14 11:33 AM
West Central Wi.
1969 HEMI R-T Offline
West Central Wi.
all of mine have them. I agree they are for the CC servo bkt. a buddy had a 68 GTX that had cruise and the bracket mounted right there!
HEMI,S ARE FOREVER!!!
Re: Extra holes on A12 LH inner fender?? [Re: 1969 HEMI R-T] #1690348
10/26/14 03:57 PM
10/26/14 03:57 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
They are "pilot holes" to be drilled for the cruise control mounting bracket (if so equipped), here's my first MOPAR - a '68 383 4bbl Charger.
There are many spot welds in that area to attach inner fender to the upper shock tower and related inner fender support.
Re: Extra holes on A12 LH inner fender?? [Re: 6bblgt] #1690349
10/26/14 04:18 PM
10/26/14 04:18 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
What is the distance from hole to hole?
What size bolts/screws are used there on the cruise control?
My 70RR has 2 holes in that spot weld "arc" but are bigger diameter holes than pictured above.
Re: Extra holes on A12 LH inner fender?? [Re: thehemikid] #1690350
10/30/14 12:48 AM
10/30/14 12:48 AM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
Are those pilot holes 3&3/16" center to center?
Re: Extra holes on A12 LH inner fender?? [Re: thehemikid] #1690351
11/05/14 09:27 PM
11/05/14 09:27 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
Ok,....Thanks!
Re: Extra holes on A12 LH inner fender?? [Re: thehemikid] #1690352
11/23/14 09:51 AM
11/23/14 09:51 AM
Virginia
HemiStan Offline OP
HemiStan  Offline OP
Virginia
Jeff,
Sorry for the delay in getting this info. Yes, the holes are 3 and 3/16" center to center.
Stan
Re: Extra holes on A12 LH inner fender?? [Re: HemiStan] #1690353
11/23/14 12:28 PM
11/23/14 12:28 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
Jeff,
Stan
That's ok Stan...I know it takes a while to count all those little lines. ...and Thanks!
I appears to me, someone had a cruise control on this 4spd car back in the 70's.
I had always wondered what someone had mounted there. I tried an MSD but it didn't match any holes. But for some reason, I guess being a 4spd, ...never even thought about cruise until I read this thread.
I've been try'n to get a hold of one of the previous owner's who bought it in about 78 to see if he remembers it being on it when he got it.
...and it's got me 'n ...it'd be nice to have.
Re: Extra holes on A12 LH inner fender?? [Re: thehemikid] #1690354
11/23/14 05:10 PM
11/23/14 05:10 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
I know of one a12 B that has extra holes in the l & r inner fender panels the owner had spark plug holder plates screwed to them.
