8 3/4 Diff Gear Lube #1690206
10/25/14 12:13 AM
10/25/14 12:13 AM
Houston Texas, USA
markfh52 Offline OP
markfh52  Offline OP
Houston Texas, USA
What gear lube would be best for the 8 3/4 posi diff. I know there's a limited slip additive that needs to be used but I was checking out Castrol 75w-90 synthetic limited slip lube. Can that be used or is there a better alternative. Thanks
Re: 8 3/4 Diff Gear Lube [Re: markfh52] #1690207
10/25/14 12:20 AM
10/25/14 12:20 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I'm going to use Torco 85w-140w racing regular dyno. with a bottle of the ford juice. It's on it's way from amazon.
Re: 8 3/4 Diff Gear Lube [Re: ademon] #1690208
10/25/14 12:59 AM
10/25/14 12:59 AM
IN
ahy Offline
ahy  Offline
IN
90 weight or 80W90 will work fine for general use. I have always used the parts store LS additive in mine (GM spec?) without issue.
Synthetic can help with temperature extremes: for really cold weather or if running sustained high speed/high temp. An xx/140 dino oil can help somewhat with high temps as well.
Re: 8 3/4 Diff Gear Lube [Re: ahy] #1690209
10/25/14 01:00 AM
10/25/14 01:00 AM
Laveen, Arizona
GTSDart340 Offline
GTSDart340  Offline
Laveen, Arizona
I just had mine give through this year. I put 80-90 in it with the LS additive. No issues so far!
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
Re: 8 3/4 Diff Gear Lube [Re: markfh52] #1690210
10/25/14 01:05 AM
10/25/14 01:05 AM
Kirkland, Washington
Pacnorthcuda Offline
Your choice would be fine. For the additive go to a Ford dealer and buy it, it's the original formula MOPAR used to use.
If your ""posi"" is a cone type the additive you choose really doesn't matter, if it's a power lock clutch unit you want to feed it the best.
Re: 8 3/4 Diff Gear Lube [Re: markfh52] #1690211
10/25/14 02:08 PM
10/25/14 02:08 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
No need for the additive if the gear oil is made for limited slip diffs. That mean there is additive already in the oil.
Re: 8 3/4 Diff Gear Lube [Re: mopowers] #1690212
10/26/14 09:04 PM
10/26/14 09:04 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Regardless of what the label says, you must always add friction modifier to a bottle of gear lube.
Re: 8 3/4 Diff Gear Lube [Re: DoctorDiff] #1690213
10/27/14 10:07 PM
10/27/14 10:07 PM
Houston Texas, USA
markfh52 Offline OP
markfh52  Offline OP
Houston Texas, USA
So if I use Castrol Syntrax Limited Slip 75W-90 I should also use something like Champion Limited Slip Differential Axle additive concentrate or like the Ford additive as suggested.
Re: 8 3/4 Diff Gear Lube [Re: markfh52] #1690214
10/28/14 12:13 AM
10/28/14 12:13 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Yes, use the Ford additive.
If you can't smell friction modifier in the gear lube, it is either not there, or there isn't enough mixed in.
Re: 8 3/4 Diff Gear Lube [Re: DoctorDiff] #1690215
10/28/14 12:19 AM
10/28/14 12:19 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Even the stuff from Richmond?
Re: 8 3/4 Diff Gear Lube [Re: GTX MATT] #1690216
10/28/14 12:54 AM
10/28/14 12:54 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I just picked up the ford additive it's 4 oz and was about $6.50 from the dealer. I haven't sniffed it yet I'll report back on the smell in a few days.
Re: 8 3/4 Diff Gear Lube [Re: ademon] #1690217
10/28/14 04:32 PM
10/28/14 04:32 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Ya it smells nasty. way more smelly than the stuff i got from NAPA that they have on the shelf. Always got a bit of popping on my truck 9 1/4 rear when i make a turn on a incline, well see if the ford stuff works better.
Re: 8 3/4 Diff Gear Lube [Re: ademon] #1690218
10/31/14 02:01 PM
10/31/14 02:01 PM
West Palm Beach, Florida
Copper Dart Offline
Copper Dart  Offline
IIRC. Someone mentioned that it's made from whale blubber.
If true, that should explain the wonderful aroma! Eskimos use it as cologne. Yummmmm.nb
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
