Page 1 of 4 1 2 3 4
My W9 Build #1690097
10/24/14 09:45 PM
10/24/14 09:45 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Some people were asking for some info.
436ci 4.04×4.25
Block: Mopar R3
Compression Ratio: 11.43:1
Crankshaft: BPE
Connecting Rods: Scat 6.2-inch I-beam
Pistons and Rings: Total Seal .043/.043/3mm rings
Camshaft: Comp 250/252 degrees at .050, .735/.685 lift, 108 degrees LSA
Cylinder Heads: Brett Miller small CNC Mopar W9 363cfm max intake flow, 255cfm exhaust flow.
Intake Manifold: Mopar 420
Matt
Re: My W9 Build [Re: MattW] #1690098
10/24/14 09:51 PM
10/24/14 09:51 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
I'm sure it will run well Matt. What size valves are in your heads? Jim
Re: My W9 Build [Re: MattW] #1690099
10/24/14 10:00 PM
10/24/14 10:00 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
That should really make some steam.
It might like a little more duration , but I guess that depends on your end use too.
Mine is a 405 ( 4.125 X 3.79 ) with a little more compression and a different cam....268 @ .050 and .680 ish lift on a 104 center and in at 102.
The heads flow less.......348 @ .700 and I think 248 on the exhaust.
I ran out of time and money so it never went on the pump , but it has more than fair street manners and really pulls once it hooks.
It ran hotter than I expected ( over 210 on hot days. ) , but I just went with the HHR fan / shroud and that fixed that issue.
Cold starting with E-85 takes a while , but if the air is over 65 or so it isn't a problem.
My plans for hitting a test day before the season was over got waylaid by a couple family weddings , but I can't wait for next spring to bury the speculation regarding what it will do.
Me thinks you're gonna really enjoy that one.
Re: My W9 Build [Re: MattW] #1690100
10/24/14 10:09 PM
10/24/14 10:09 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
timing chain (do you have a cover?)? or weber belt drive?
keeping the stock front end?
got a header builder handy?
2 speed trans? ....or torqueflight torture (I chose the latter so far...)
running a 4500 carb? or sticking with a 4150? My 598 intake and spacer for 4500 sits to high....going to have the intake modded to a 4500 flange eventually.
Re: My W9 Build [Re: MattW] #1690101
10/24/14 10:13 PM
10/24/14 10:13 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
436ci 4.04×4.25
Block: Mopar R3
Crankshaft: BPE
Matt
Do you think you'll overpower that rod with this combo?
That crank has a 2.00 rod journal right? Didnt know scat made a 6.200 I beam with a 2.00 big end.
Re: My W9 Build [Re: J_BODY] #1690102
10/25/14 12:06 AM
10/25/14 12:06 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
All pertinent questions.
Weber belt and front drive distributor here....mostly for show and tell.
And an AlterKtion or I'd never even try making headers for it.
I went under sized with the carb.........a QuickFuel 850 done for E-85.
One of a couple compromises I made to keep some manners.
I made my own headers....1 7/8" X 35 " primaries into a 3 1/2" collector.
I bought a set of Flowmaster 4 into 2 into 1 - 3" collectors , added tubes for the evac and had them coated only to decide that enhancing low end torque was not going to be a priority.
And a low 1st gear 904 with a 3.91 rear cog that feels O.K. , but it runs out of first in a big hurry.
3200 rpm @ 55 mph .......not horrible , but I don't see any long trips in my future.
Re: My W9 Build [Re: tubtar] #1690103
10/25/14 01:11 AM
10/25/14 01:11 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I removed my 1050 and spacer and installed the "supposed" 930 cfm BG 4150 carb we ran on the 360. figured it will be a good carb for the learning curve. It's funny..... racing/working on the Mirada for 26 years I never had the "joy" of working around steering linkage and torsion bars. As sad as it sounds that was a huge factor in me having a tube K put together with coil overs and a steering rack for the Duster. Made life ALOT easier.
Re: My W9 Build [Re: MattW] #1690104
10/25/14 02:01 AM
10/25/14 02:01 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Should make a True 750,but I think the carb will need to be bigger by alot.
sb Mopars imo love carburation atleast all mine have.
Re: My W9 Build [Re: fishy340] #1690105
10/25/14 05:44 AM
10/25/14 05:44 AM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
a very nice combo,should be a reliable and run hard
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: My W9 Build [Re: tubtar] #1690106
10/25/14 09:48 AM
10/25/14 09:48 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
What block are you using? Why such a small bore?
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: My W9 Build [Re: 1967dartgt] #1690107
10/25/14 10:26 AM
10/25/14 10:26 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Seems like a waste to run such a tiny cam and bore on a motor/ heads with a lot of potential.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: My W9 Build [Re: B3422W5] #1690108
10/25/14 10:59 AM
10/25/14 10:59 AM
The Great White North
RAMM Offline
RAMM  Offline
The cam is not the limiting factor. I agree about the bore but the R3 we used was sonic checked and 4.070" is all there is fo0r future overb0ores. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: My W9 Build [Re: J_BODY] #1690109
10/25/14 11:16 AM
10/25/14 11:16 AM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Stock
Yes
No
727.
My carb will be 1025 race demon.
Re: My W9 Build [Re: Hot 340] #1690110
10/25/14 11:21 AM
10/25/14 11:21 AM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
436ci 4.04×4.25
Block: Mopar R3
Crankshaft: BPE
Matt
Don't know about the rods but everything I've read is stroke and speed. This thing is all done at 6500 rpm.
They do unless I was given wrong info. Matt
Re: My W9 Build [Re: MattW] #1690111
10/25/14 11:32 AM
10/25/14 11:32 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
The little enginemaster's 318 I bought has a 6.200 Scat I beam Chevy rod in it.
1.41 best 60 foot
6.60 at 103.90 1/8
Re: My W9 Build [Re: B3422W5] #1690112
10/25/14 12:11 PM
10/25/14 12:11 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Trying to figure out how to transfer pictures from my galaxy s4 to this post.
Before it when to engine masters it was dynoed at 665 hp and 630 tq.
Matt
Re: My W9 Build [Re: MattW] #1690113
10/25/14 01:06 PM
10/25/14 01:06 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
436ci 4.04×4.25
Block: Mopar R3
Crankshaft: BPE
Matt
NICE combination! Whats the bobweight? I would think you'd be fine w/ those rods if the bobwt isn't way up there. I put 6.250 rods in mine and really like the characteristics of the engine.
Yeah, it's got a smallblock.
Re: My W9 Build [Re: B3422W5] #1690114
10/25/14 01:45 PM
10/25/14 01:45 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
sometimes "potential" is pretty hard on stuff....
Re: My W9 Build [Re: B3422W5] #1690115
10/25/14 01:56 PM
10/25/14 01:56 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
My first thaught.............hugh lift but baby duration........
Re: My W9 Build [Re: Thumperdart] #1690116
10/25/14 02:30 PM
10/25/14 02:30 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Keep in mind that this venture was a last minute deal so to speak.
The stuff that's in this engine is stuff that was already purchased.
I was not built specifically for engine masters.
It was more of let's see what all this can do.
I had a couple of limiting factors one being a hydraulic roller and compression.
I want to be able to drive this thing around town if I ever get my junk together.
Matt
Page 1 of 4 1 2 3 4
