1bbl carburetor #1689817
10/23/14 11:32 PM
10/23/14 11:32 PM
Visalia, CA.
P
poison_ivy Offline OP
P
Visalia, CA.
Got myself a '65 A100 pickup recently with a slant six. Have been reading a bit lately about a 2-1bbl manifold from Offenhauser. My truck has a Carter carburetor, and I know Holly had a carb for these motors. Given the choice, which is the better one to find parts for and work on? Thanks.
Re: 1bbl carburetor [Re: poison_ivy] #1689818
10/24/14 10:55 AM
10/24/14 10:55 AM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
As an old chrysler tech. 1965 to 1978.I remember that the Carter carb came on the 170 cid slant,and the Holley came on the 225 cid slant..both worked fine..The Carter was easier to work on but the Holley wasn't hard...I see them both at swap meets all the time..and kits are avalible
Re: 1bbl carburetor [Re: poison_ivy] #1689819
10/24/14 12:15 PM
10/24/14 12:15 PM
As said they are both pretty simple. You would be able to swap jets on the holley & iirc all carter primary jets are the same (other than orifice dia) so you could swap jets. You might inquire over at www.slantsix.org as those guys have dealt with them almost exclusively for decades. Doug Dutra and Chuck Rivers would be 2 good guys to pick their brains on that question. EDIT I just remembered that AVS pri jets are tall jets for the 3 step rods and AFB used shorter ones & these might be the ones to use or Eddy jets which'd sure be easier to come by
Re: 1bbl carburetor [Re: RapidRobert] #1689820
10/24/14 10:35 PM
10/24/14 10:35 PM
Visalia, CA.
P
P
Visalia, CA.
Thanks guys. I'm seriously considering the dual 1bbl set up just for the cool factor. I don't need more power, I just want the cool look!
Re: 1bbl carburetor [Re: poison_ivy] #1689821
10/24/14 11:07 PM
10/24/14 11:07 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Use the Offy 2x1 intake, 2 Holley 1920s and 2 unsilenced air cleaners from a pre-67 slant and it will look like it's a factory option. Offy has a linkage kit to connect the carbs together along with the throttle and kick down. The bonus is doubled carb air flow, which will be around 350cfm, 1920s are 160-180 cfm.
The 67-up air cleaners use a larger 10" filter and the carb spacing is less than 10" so they interfere with each other.
Re: 1bbl carburetor [Re: B5 Bee] #1689822
10/25/14 02:10 AM
10/25/14 02:10 AM
Visalia, CA.
P
P
Visalia, CA.
Thanks guys. Really appreciate all the info.
