6bbl to 4bbl any gains? #168976
12/16/08 10:04 PM
12/16/08 10:04 PM
Anonymous OP
Anonymous OP
I'm going to switch from my 6bbl to a victor intake and 950 carb.Just wondering what gains i could expect. Motor is in 69 roadrunner 470with cnc'd eddy's 10.6 comp 1 7/8 hookers 590ish cam with 260ish dur.@50 391gears 28in tall tire 3500 stall car ran best of 11.30@121 thanks for any input or suggestons. EDDIE B
Re: 6bbl to 4bbl any gains? #168977
12/16/08 10:18 PM
12/16/08 10:18 PM
Connecticut
5126brl No more Offline
Connecticut
I have a 451 with a stock six pack, bulldog heads and a 260-266 cam. made 591 hp.
480 @ the wheels.
I think you may pick up 25 hp with a switch to 950.
Re: 6bbl to 4bbl any gains? #168978
12/16/08 10:39 PM
12/16/08 10:39 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
My non-MW port EZ headed, hydraulicly cammed 493" wedge makes 682 hp at 5500 rpm with a sixpack and I'd have to double check but if memory serves it made 685hp with a four barrel, so not too much difference on mine.
Re: 6bbl to 4bbl any gains? [Re: jbc426] #168979
12/16/08 11:03 PM
12/16/08 11:03 PM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
I would say 15-20hp,
It's not the carbs that is the problem....it's the six pack intake that hurts you.
Just my
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
Re: 6bbl to 4bbl any gains? #168980
12/16/08 11:16 PM
12/16/08 11:16 PM
I have seen and did similar changes to a lot of 440 type motors with stock size intake ports, all of them slowed down in the 1/4 ET and MPH when decreasing the total CFM, regardless of intakes used I did a dyno test on my low deck stroker two winters ago, removed the six pak and replaced it with a 1050 dominator carb and intake, the motor lost 8 hp and had the exact same torque More CFM on a big block Mopar with stock type heads,ported or unported, makes more power in my opinion and experiences
Re: 6bbl to 4bbl any gains? #168981
12/16/08 11:44 PM
12/16/08 11:44 PM
iowa
copchaser Offline
copchaser  Offline
iowa
What kind of RPM are you turning? I've posted some dyno results a while back, April or May. I was having my 535 dyno'ed and I did a intake shoot out. The 4 barrel was king, a heavy modified M1 and made I think 20 horse over the 6-pack, the 4-barrel made 12 horse over a tunnelram and I tryed a mopar crossram, it was a piece of junk. All of the manifolds were ported. just my
Re: 6bbl to 4bbl any gains? #168982
12/17/08 12:03 AM
12/17/08 12:03 AM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
11.30 is a little slow for 121 mph. whats the 60 foot? i think there is a possibility the victor could slow you down with only 3500 stall.
Re: 6bbl to 4bbl any gains? [Re: forphorty] #168983
12/17/08 12:07 AM
12/17/08 12:07 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
The big high rise Victor might hurt you down low, and the engine might not spin high enough to see a gain up top. I bet it wont be worth the hassle either way.
Re: 6bbl to 4bbl any gains? [Re: jbc426] #168984
12/17/08 04:06 AM
12/17/08 04:06 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
682 ???
what are the specs on this HYd. cam motor ?
Re: 6bbl to 4bbl any gains? [Re: 493_DART] #168985
12/17/08 09:53 AM
12/17/08 09:53 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
send a pm to BSB67, (russ). i've known russ for a long time and you'll probably get more real world intelligent information on what your trying to do from him. he's working with single 4bbl stuff on his car and has dyno numbers and track time.
Re: 6bbl to 4bbl any gains? [Re: jbc426] #168986
12/17/08 10:05 AM
12/17/08 10:05 AM
Connecticut
Connecticut
You are running a hyd. roller, correct?
Also I saw the flow numbers on your intake, Is that a stock 69 style or the later reproduction intake? those numbers are huge for a factory intake.
Re: 6bbl to 4bbl any gains? [Re: 5126brl No more] #168987
12/17/08 10:49 PM
12/17/08 10:49 PM
Anonymous OP
Anonymous OP
would it work better with more convertor or just change convertor and leave 6bbl?
Re: 6bbl to 4bbl any gains? #168988
12/18/08 01:51 PM
12/18/08 01:51 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'm going to switch from my 6bbl to a victor intake and 950 carb.Just wondering what gains i could expect. Motor is in 69 roadrunner 470with cnc'd eddy's 10.6 comp 1 7/8 hookers 590ish cam with 260ish [Email]dur.@50[/Email] 391gears 28in tall tire 3500 stall car ran best of [Email]11.30@121[/Email] thanks for any input or suggestons. EDDIE B
That's not bad considering the weight of your car and gear. I'm not sure you'll see any gain. The Victor is for higher rpms and might not have the low end the 6-pack has. My buddy runs about the same set-up in a 68 dart w/ a 850DP but w/ more stall and gear and runs 10.80's. What about re-tuning your 6-pack or trying some 4.30's??
