1970 B-body Disc Spindles #1689620
10/23/14 01:42 PM
10/23/14 01:42 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Can you go straight to an 11.75 rotor and slider caliper/bracket on this rotor if you've already got the KH brakes?
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: 1970 B-body Disc Spindles [Re: AlexP] #1689621
10/23/14 02:15 PM
10/23/14 02:15 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
No, not as is. You can buy a pair of the Dr.Diff bearing spacers and then it works just fine. I just did the same swap on my '70 Bee, but used the pin style.
