Carbureter and ignition recommendations please #1689607
10/23/14 11:35 AM
10/23/14 11:35 AM
Northern IL
meathead66 Offline OP
Northern IL
Mostly street engine. 11.5 400 stroked to 406" dynoed @ 610HP with 498 torque. Victor intake, Edelbrock heads, Bullet cam
Anything other info needed?
Re: Carbureter and ignition recommendations please [Re: meathead66] #1689608
10/23/14 11:38 AM
10/23/14 11:38 AM
Earth
Rob C Offline
Rob C  Offline
Earth
What carb did they dyno it with?
Re: Carbureter and ignition recommendations please [Re: Rob C] #1689609
10/23/14 11:44 AM
10/23/14 11:44 AM
Northern IL
Northern IL
Don't know cause this was the 2011 Amsoil engine 3rd placer and difficult getting strait answers. It was built for dyno but I plan on 90% street use. Yes I know its not built for street but the price was in my budget.
BTW it also has the Harlan/Sharpe 1.6 rockers.
Re: Carbureter and ignition recommendations please [Re: meathead66] #1689610
10/23/14 12:08 PM
10/23/14 12:08 PM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
How many cubes? 406" or 496"
Re: Carbureter and ignition recommendations please [Re: 80fbody] #1689611
10/23/14 12:11 PM
10/23/14 12:11 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
That was my first thaught. I`d go 1050 dominator PROPERLY calibrated to your car..........
Re: Carbureter and ignition recommendations please [Re: Thumperdart] #1689612
10/23/14 01:18 PM
10/23/14 01:18 PM
Northern IL
Northern IL
Its a 406" (4.375 bore 9.98 deck height) steel 383 crank (3.375 stroke 2.200 journals) ICON pistons (.033 over 1.480 comp height)
Isn't that Dominator a bit big for the street?
Re: Carbureter and ignition recommendations please [Re: meathead66] #1689613
10/23/14 01:43 PM
10/23/14 01:43 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I thaught it was a miss-print when you said "stroked" 400.........Yes, you could use less carb 750-850 can easily be tailored to work 4 u.
Re: Carbureter and ignition recommendations please [Re: meathead66] #1689614
10/23/14 02:41 PM
10/23/14 02:41 PM
Cab_Burge Online work
Cab_Burge  Online Work
The drivers right foot controls how far open the throttle blades get I've never seen a Mopar BB wedge motor yet have to much carburetion, tunnel ram, six pak or single carb. I've seen a bunch that ran better after putting a bigger carb. on them Maybe a 950 or 1000 CFM 4150 carb. would make you happy
Re: Carbureter and ignition recommendations please [Re: meathead66] #1689615
10/23/14 06:39 PM
10/23/14 06:39 PM
Locomotion Offline
Locomotion  Offline
I put a Mallory HyFire VI AL ignition box, 32 series billet, magnetic p/u distributor and recommended coil on my race car many years ago and it's worked great. Only a little trouble with one of the connectors. I haven't messed with it besides changing cap, rotor & Accel 8.8 plug wires periodically. This is their low deck BB version at Summit:
Mallory 32 series distributor for low deck Mopar BB.
As for carbs, I only know how to work on Holley's and their Ultra series work well for me, at the track at least. Staying just a little on the conservative side with CFM could help drivability & tunability.
Re: Carbureter and ignition recommendations please [Re: Locomotion] #1689616
10/23/14 10:27 PM
10/23/14 10:27 PM
Northern IL
Northern IL
OK any opinions on this Holley 950 CFM with mechanical secondaries?
https://www.holley.com/products/fuel_systems/carburetors/hp/street_hp/parts/0-82951
The motor came with the MSD 8545 Billet distributor and will need a box and harness, any ideas?
Appreciate all the help.
Re: Carbureter and ignition recommendations please [Re: meathead66] #1689617
10/23/14 10:53 PM
10/23/14 10:53 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Never worked w/that particular one but again, there`s still some small tweeks that yield big results..........
