Noisy electric fuel pump #1689452
10/23/14 12:06 AM
10/23/14 12:06 AM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Any tricks to quieting an electric fuel pump? I'm running an Aeromotive 11253 polished fuel pump mounted to my passenger side framerail and with fairly quiet turbo mufflers this thing is extremely annoying as I'm told by my wife and son lol.
I'm gonna try thick rubber washers between the pump and the frame. Would a rubber-lined aluminum housing around the top of the pump direct the noise toward the ground or would it just cause a heat problem?
I've heard the Mallory140 pumps are very quiet, is this true?
Re: Noisy electric fuel pump [Re: ProSport] #1689453
10/23/14 12:17 AM
10/23/14 12:17 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I would do more than just rubber washers, you need to isolate it from the chassis a little better.
A studded rubber mount, stock sway bar end link bushing, something like that ran with a nyloc nut and a little preload will do some decent dampening. Rubber between the pump and mount, assuming it's a band, could help some as well.
Also make sure there is a little rubber line in the system to help isolate the hardline from the pump and vibrating on the frame from the pump to the engine.
Some ideas on mounting, "Versa-Mount Vibration-Damping Mounts" or maybe "
Chemical-Resistant Vibration-Damping Sandwich Mounts"
http://www.mcmaster.com/#rubber-mounts/=u9pt21
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Noisy electric fuel pump [Re: ProSport] #1689454
10/23/14 08:47 AM
10/23/14 08:47 AM
Idaho
1320Dart Offline
1320Dart  Offline
Idaho
When mounting the pump to your frame rail, use the same isolaters that MSD uses on their 7AL-3's.
That should tame it down a bit.
Greg
Cost is irrelevant, making memories is far more valuable!biggrin
Re: Noisy electric fuel pump [Re: ProSport] #1689455
10/23/14 09:20 AM
10/23/14 09:20 AM
off the grid
340B5 Offline
340B5  Offline
off the grid
My Mallory 140 is fairly quiet. Last test was 112gph through 40 and 10 micron filters@6.5 psi
Yeah, it's got a smallblock.
Re: Noisy electric fuel pump [Re: 1320Dart] #1689456
10/23/14 09:28 AM
10/23/14 09:28 AM
Odessa, Fl
blowndart Offline
blowndart  Offline
Odessa, Fl
Made a huge difference with My Aeromotive Pump.
Re: Noisy electric fuel pump [Re: blowndart] #1689457
10/23/14 10:20 AM
10/23/14 10:20 AM
an8sec70cuda Offline
I was going to suggest the same thing. A thin rubber washer won't do much, if anything. Using those thick/tall MSD mounts ought to do a good job.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Noisy electric fuel pump [Re: blowndart] #1689458
10/23/14 10:25 AM
10/23/14 10:25 AM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Re: Noisy electric fuel pump [Re: GoodysGotaCuda] #1689459
10/23/14 10:27 AM
10/23/14 10:27 AM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
2 of these might work also....
http://m.summitracing.com/parts/omx-1747017
Re: Noisy electric fuel pump [Re: ProSport] #1689460
10/23/14 11:51 AM
10/23/14 11:51 AM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Well ----- it is a street car so turn the radio up!!!!!
Russ
Re: Noisy electric fuel pump [Re: max_maniac] #1689461
10/23/14 12:18 PM
10/23/14 12:18 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Excellent idea Russ! I could also cruise by myself, no whining!
Re: Noisy electric fuel pump [Re: ProSport] #1689462
10/23/14 01:00 PM
10/23/14 01:00 PM
Idaho
1320Dart Offline
1320Dart  Offline
Idaho
Greg
Re: Noisy electric fuel pump [Re: ProSport] #1689463
10/23/14 01:07 PM
10/23/14 01:07 PM
Berlin, Germany
Flo Offline
Flo  Offline
Berlin, Germany
Return style regulator should help.....
Greets
Flo
1967 Fury III 4door HT tiny 318, late model roller block, bored and stroked to 344
Re: Noisy electric fuel pump [Re: 1320Dart] #1689464
10/23/14 02:44 PM
10/23/14 02:44 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
How is this for a noisey pump
https://www.youtube.com/watch?v=wb5O8Uy4xy0&list=UUwrndkz6uZ0eFdMoXjKgmEw
The video really makes it worse than it was. We always assumed it was from the camera mount and the way the pump was mounted in the car
Re: Noisy electric fuel pump [Re: Al_Alguire] #1689465
10/23/14 05:31 PM
10/23/14 05:31 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
My wife said "That just sounds ridiculous" LOL.
Your fuel pump sounds like it could power your rear wheels Al, probably run 10's!
Re: Noisy electric fuel pump [Re: Al_Alguire] #1689466
10/23/14 05:37 PM
10/23/14 05:37 PM
Idaho
1320Dart Offline
1320Dart  Offline
Idaho
Just watched your video. It sounds just like mine. It's not just the camera. That noise actually transmits through the chassis to the camera mount.
Greg
Re: Noisy electric fuel pump [Re: 1320Dart] #1689467
10/23/14 06:12 PM
10/23/14 06:12 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
That was a BIG fuel pump. Maybe I should have tried with it that way , sure sounds stout. Besides running 10's would be more fun than bottom 8's NA at 3300lbs gets boring anyway
BTW for those wondering that was the famous Gypsy Mike(of Street Outlaws fame)in the other lane you never saw
Re: Noisy electric fuel pump [Re: ProSport] #1689468
10/24/14 11:20 PM
10/24/14 11:20 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
I installed a couple of these tonite and it definitely cut out 50% of the pump noise but these mounts are very flimsy, fuel pump easily falls over so I'm gonna have to get another pump mounting bracket and 2 more of these rubber mounts so I can install it towards the top of the pump also, if there is room in there.
I should have tried those jeep mounts I posted but I found these 2 little rubber mounts in my garage so I used them.
Re: Noisy electric fuel pump [Re: Flo] #1689469
10/24/14 11:32 PM
10/24/14 11:32 PM
alaska,usa
9
9secondsatellite Offline
alaska,usa
Greets
Flo
that's what i was thinking. is it dead headed?
Re: Noisy electric fuel pump [Re: ProSport] #1689470
10/24/14 11:32 PM
10/24/14 11:32 PM
Harm City Md.
Dan Halen Offline
Dan Halen  Offline
Harm City Md.
I isolated my electric pump in a similar fashion, it cut the dbs down about 20%, the noise was still transmitting through the metal fuel line running up the frame rails. I went with a high capacity mechanical pump and all is good.
Re: Noisy electric fuel pump [Re: Dan Halen] #1689471
10/25/14 12:01 AM
10/25/14 12:01 AM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Yes, it's dead-headed.
