Noisy electric fuel pump
#1689452
10/23/14 12:06 AM
10/23/14 12:06 AM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
Any tricks to quieting an electric fuel pump? I'm running an Aeromotive 11253 polished fuel pump mounted to my passenger side framerail and with fairly quiet turbo mufflers this thing is extremely annoying as I'm told by my wife and son lol. I'm gonna try thick rubber washers between the pump and the frame. Would a rubber-lined aluminum housing around the top of the pump direct the noise toward the ground or would it just cause a heat problem? I've heard the Mallory140 pumps are very quiet, is this true?
Re: Noisy electric fuel pump
[Re: ProSport]
#1689453
10/23/14 12:17 AM
10/23/14 12:17 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I would do more than just rubber washers, you need to isolate it from the chassis a little better. A studded rubber mount, stock sway bar end link bushing, something like that ran with a nyloc nut and a little preload will do some decent dampening. Rubber between the pump and mount, assuming it's a band, could help some as well. Also make sure there is a little rubber line in the system to help isolate the hardline from the pump and vibrating on the frame from the pump to the engine. Some ideas on mounting, "Versa-Mount Vibration-Damping Mounts" or maybe " Chemical-Resistant Vibration-Damping Sandwich Mounts" http://www.mcmaster.com/#rubber-mounts/=u9pt21
[Re: ProSport]
#1689454
10/23/14 08:47 AM
10/23/14 08:47 AM
Posts: 503 Idaho
1320Dart
Idaho
When mounting the pump to your frame rail, use the same isolaters that MSD uses on their 7AL-3's. That should tame it down a bit.
Greg ----------------------------------------------------------------- Cost is irrelevant, making memories is far more valuable!
[Re: ProSport]
#1689455
10/23/14 09:20 AM
10/23/14 09:20 AM
Posts: 1,532 off the grid
340B5
off the grid
My Mallory 140 is fairly quiet. Last test was 112gph through 40 and 10 micron filters@6.5 psi
Yeah, it's got a smallblock.
[Re: 1320Dart]
#1689456
10/23/14 09:28 AM
10/23/14 09:28 AM
Posts: 965 Odessa, Fl
blowndart
Odessa, Fl
Made a huge difference with My Aeromotive Pump.
[Re: blowndart]
#1689457
10/23/14 10:20 AM
10/23/14 10:20 AM
Posts: 13,362 Marion, South Carolina [><]
an8sec70cuda
I was going to suggest the same thing. A thin rubber washer won't do much, if anything. Using those thick/tall MSD mounts ought to do a good job.
[Re: ProSport]
#1689462
10/23/14 01:00 PM
10/23/14 01:00 PM
Posts: 503 Idaho
1320Dart
Idaho
[Re: ProSport]
#1689463
10/23/14 01:07 PM
10/23/14 01:07 PM
Posts: 401 Berlin, Germany
Flo
Berlin, Germany
Return style regulator should help.....
Greets Flo
1967 Fury III 4door HT
tiny 318, late model roller block, bored and stroked to 344
[Re: Flo]
#1689469
10/24/14 11:32 PM
10/24/14 11:32 PM
Posts: 527 alaska,usa
9secondsatellite
alaska,usa
Greets Flo
that's what i was thinking. is it dead headed?
