1968 Bbody Kframe in 1964/65 Bbody question #1689318
10/22/14 09:02 PM
10/22/14 09:02 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
When fitting a 68 kframe in a 64/65 do you use the later idler arm or the correct year model item . The pitman arms , manual steer , appear to be the same . I do have a 68 steering box to use .
I know the motor sets back about 1 1/2" . I presume header choice is not compromised . I am using a Milodon road race pan .
If I do this I will look to fit heim joint strut rods at the same time
Am I missing anything ?
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: 1968 Bbody Kframe in 1964/65 Bbody question [Re: tex013] #1689319
10/22/14 09:08 PM
10/22/14 09:08 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
You use what ever is called for on a 68 car.
Re: 1968 Bbody Kframe in 1964/65 Bbody question [Re: tex013] #1689320
10/22/14 09:10 PM
10/22/14 09:10 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
Unless you are using a motor plate that frame will move the motor in the wrong spot. It will move it forward about 1 1/2 in. Then you will have header fitment problems. Sorry read it wrong. You use 68 parts and 66 and later headers and a modified trans mount.
Re: 1968 Bbody Kframe in 1964/65 Bbody question [Re: JAKE68] #1689321
10/22/14 09:55 PM
10/22/14 09:55 PM
south central pa
bdaz smblk Offline
bdaz smblk  Offline
south central pa
It will move the motor back about 2 inches.Then if u run a 727 u just have to cut a small piece of the trans tunnel out for clearance.We did it to my dads 63 ply and it worked real nice.
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
Re: 1968 Bbody Kframe in 1964/65 Bbody question [Re: bdaz smblk] #1689322
10/22/14 11:16 PM
10/22/14 11:16 PM
south central nebraska
GI Moparman Offline
GI Moparman  Offline
It moves engine back 1 5/8. I used a 70 k frame in my 65 coronet. I then relocated the factory mounts ahead to make tranny xmemeber line up. I did this cuz I used the shumoker hemi mounts to a v8 70 k frame.
Re: 1968 Bbody Kframe in 1964/65 Bbody question [Re: GI Moparman] #1689323
10/22/14 11:26 PM
10/22/14 11:26 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
thanks guys
Tex
New best MPH 130.32
Re: 1968 Bbody Kframe in 1964/65 Bbody question [Re: tex013] #1689324
10/24/14 01:09 AM
10/24/14 01:09 AM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
We did this swap on a 64 Plymouth about 6 years ago. Use the front end components from the year specific K-frame. The pinch weld in the tunnel will have to be flattened and you will need to use a BFH on the tunnel where the accumulator in the trans will contact the tunnel. Kick-down linkage, if used, can be made to work if you use the one-piece unit. The crossmember can be modified and use the cheaper 66 and later trans mount. 66 & later headers will work and a 66 and later oil pan will fit. Will post pics.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: 1968 Bbody Kframe in 1964/65 Bbody question [Re: Dads426] #1689325
10/24/14 01:15 AM
10/24/14 01:15 AM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
Trans mount. I mocked up a block and trans case in the car to get the correct position of the pocket for the mount.
Re: 1968 Bbody Kframe in 1964/65 Bbody question [Re: Dads426] #1689326
10/24/14 01:22 AM
10/24/14 01:22 AM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
Bottom pic. Pocket is a piece of 2x3" rectangular tubing, boxed on the bottom.
Re: 1968 Bbody Kframe in 1964/65 Bbody question [Re: Dads426] #1689327
10/24/14 01:23 AM
10/24/14 01:23 AM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
I have a 67 K frame in my 65 -
I have 66 up headers and a scatter shield - the clutch linkage is a perfect line up - goes right through the header opening.
My 6 cylinder b body 65 Z bar is a close fit as well.
I gutted a stock 65 trans cross member and have tacked in a trans mount out of a diplomat - I cut the metal out of the dippy trans mount and its a near perfect fit for the 65 cross member. I might have pics.
Re: 1968 Bbody Kframe in 1964/65 Bbody question [Re: NTOLERANCE] #1689328
10/24/14 01:35 AM
10/24/14 01:35 AM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
When I went to replace and or check the pitman and idler arms - Napa listed the same part numbers for 65 and 67.
Maybe they ahve it incorrect - but I would use the same years.
Both of mine are early B body
Re: 1968 Bbody Kframe in 1964/65 Bbody question [Re: NTOLERANCE] #1689329
10/24/14 02:16 AM
10/24/14 02:16 AM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
thanks for the extra info and pics .
Tex
New best MPH 130.32
Re: 1968 Bbody Kframe in 1964/65 Bbody question [Re: tex013] #1689330
10/25/14 10:28 PM
10/25/14 10:28 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
Gutted stock unit with diplomat center
Re: 1968 Bbody Kframe in 1964/65 Bbody question [Re: NTOLERANCE] #1689331
10/25/14 10:59 PM
10/25/14 10:59 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
Quick mock up
Re: 1968 Bbody Kframe in 1964/65 Bbody question [Re: NTOLERANCE] #1689332
10/27/14 01:04 AM
10/27/14 01:04 AM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
Painted and in
